It has been nearly 3 years since I last posted on my Camaro build (wow time flies).  I decided in my boredom (eff you COVID) that I would make some changes and add some speakers and fix some things.  Sooooo, I decided to replace the rear speakers (I left the stock in place originally).  Since its just the rear deck for fill mostly, I decided on coaxial speakers and thought I try RF T1s.  I also will add some speakers to the side panels in the rear (same RF T1s).  So I bought 2 pair.  Time to get to work!
Fabbed up some speaker wires.  I originally tapped the rear speakers for speaker level input to a JL Audio Cleansweep.  So, all I have is rear speaker output, which normally is fine.  However, I cannot fade from to back doing it this way, nor can I hear the turn signal noise or use bluetooth for phone calls since they use the front speakers.
I will fix that using these speaker cables.  There are 3 pairs of wires in each, 1 pair will take audio back to the Cleansweep, the other 2 pair will send signal back to speakers.  Its clugey, but whatever.
  • 3 weeks later...
  • 1 month later...
