Smokey McPot Posted April 10, 2021 Report Share Posted April 10, 2021 What is the best amp for x15 v2, sfb 3000 or taramps smart 3k? Link to comment Share on other sites More sharing options...
1point21gigawatts Posted April 10, 2021 Report Share Posted April 10, 2021 What’s you vehicles electrical consist of? Them sfb amps are current hungry. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
Smokey McPot Posted April 10, 2021 Author Report Share Posted April 10, 2021 I did big 3 have stock alt but planned on putting extra battery in trunk Link to comment Share on other sites More sharing options...
1point21gigawatts Posted April 10, 2021 Report Share Posted April 10, 2021 I recommend a smart 3 then. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted April 10, 2021 Report Share Posted April 10, 2021 Put a 120ah agm battery or bigger in your trunk. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
Dafaseles Posted April 10, 2021 Report Share Posted April 10, 2021 Just now, 1point21gigawatts said: I recommend a smart 3 then. I second this 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Smokey McPot Posted April 10, 2021 Author Report Share Posted April 10, 2021 What amp is better I’ll get the electrical upgrades if I need to I just want to get the best amp for the sub. What would I need for electrical upgrades? Link to comment Share on other sites More sharing options...
liteblue Posted April 10, 2021 Report Share Posted April 10, 2021 Sfb 3000 did more power on the dyno vs taramps. But both amps are beast's dollar to watt. Get which ever you can get cheaper. Unless you plan on going below 1 ohm but half bridge amp with the same power can be double the price. Get two new batteries. A xs power D series under the hood and the largest XP series you can afford for the trunk. There are other great brands I only have experience with xs power. Atleast replace factory battery before secondary if it is not agm and more then 5 years old. 3 years if you live some place with harsh winter or extreme heat. Link to comment Share on other sites More sharing options...
1point21gigawatts Posted April 10, 2021 Report Share Posted April 10, 2021 9 minutes ago, liteblue said: Sfb 3000 did more power on the dyno vs taramps. But both amps are beast's dollar to watt. Get which ever you can get cheaper. Unless you plan on going below 1 ohm but half bridge amp with the same power can be double the price. Get two new batteries. A xs power D series under the hood and the largest XP series you can afford for the trunk. There are other great brands I only have experience with xs power. Atleast replace factory battery before secondary if it is not agm and more then 5 years old. 3 years if you live some place with harsh winter or extreme heat. Smart 3s can play at .5 ohm no problem, long term. My homeboy has his wired at .6 ohm, no problems. Plenty of full bridge Brazilian amps can play long term at .5 ohm. Brazilian amps have came a long way. Efficiency is the only problem. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted April 10, 2021 Report Share Posted April 10, 2021 59 minutes ago, Smokey McPot said: What amp is better I’ll get the electrical upgrades if I need to I just want to get the best amp for the sub. What would I need for electrical upgrades? If you can upgrade your electrical then I would go with an sfb amp because those amps are better on rise. The smart 3s aren’t as impressive as we thought, when impedance rise comes into play. And smart 3s don’t do 3000 rms at 2ohms. Only at 1ohm. Same homeboy that has his wired at .6 ohm sends me amm1 readings. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
