Smokey McPot Posted May 5, 2021 Report Share Posted May 5, 2021 I just got a sundown x15 with a sfb3000 What electrical upgrades would I need i have a 05 Honda Accord v6 3.0 Link to comment Share on other sites More sharing options...
Dafaseles Posted May 5, 2021 Report Share Posted May 5, 2021 Do you happen to know what your alternator amperage is? 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Smokey McPot Posted May 5, 2021 Author Report Share Posted May 5, 2021 18 minutes ago, Dafaseles said: Do you happen to know what your alternator amperage is? I believe my stock alt is 130 Link to comment Share on other sites More sharing options...
BassMunky Posted May 5, 2021 Report Share Posted May 5, 2021 Batt alt wiring Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Dafaseles Posted May 5, 2021 Report Share Posted May 5, 2021 Yeah dude, those SFB amps are beasts. You gotta feed the beast. I feel like doing the big 3, at least 270 amps of alternator (more is always better, you can't have too much electrical) and 2 80 ah (or more) AGM batteries should scrape you by. Or, if you're willing to do a battery delete, 1 lithium and 270 amp alternator should suffice. 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 9, 2021 Report Share Posted May 9, 2021 Wired at what nominal load? Id bet a second battery would be more than fine, with some up graded wiring. If your just doing music, not burping, wired down, youll be ok, adding a second battery is all. No need for 11 alternators for what, 1800 watts. (on music), and yes i know, it says it does 3k at 1ohm, but unless your wiring down to like 1/4 ohm, and doing burps, youll be ok, Music is dynamic, you wont see anywhere near full output, or load. Edit- replace your oem battery with a nice stout one, with (obviously) needed wire. Play it, watch your voltage, add a battery IF needed. Bet you may not even need that. Cheers. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
BassMunky Posted May 14, 2021 Report Share Posted May 14, 2021 Wpwww Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
