1point21gigawatts Posted May 23, 2021 Report Share Posted May 23, 2021 Sa subwoofer are a good choice. A taramps smart 3 would do well on them subwoofers. I’ve seen multiple amm1 readings on that amp and it would be a good amp on them subwoofers at 1 ohm on that enclosure you designed. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
JonDoe Posted May 23, 2021 Author Report Share Posted May 23, 2021 the smart 3 looks like a good way to go. would it be safe under my false floor Link to comment Share on other sites More sharing options...
JonDoe Posted May 23, 2021 Author Report Share Posted May 23, 2021 and just to be clear the second box with the 4" port and 4cuft? or the first one with the 3" port and slightly smaller cuft? Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 23, 2021 Report Share Posted May 23, 2021 28 minutes ago, JonDoe said: the smart 3 looks like a good way to go. would it be safe under my false floor No way. Not a taramps. 19 minutes ago, JonDoe said: and just to be clear the second box with the 4" port and 4cuft? or the first one with the 3" port and slightly smaller cuft? The second enclosure. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 23, 2021 Report Share Posted May 23, 2021 If you want to put an amp there, it can’t be a taramps. What’s your budget on an amp? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
JonDoe Posted May 23, 2021 Author Report Share Posted May 23, 2021 around 400$ Link to comment Share on other sites More sharing options...
JonDoe Posted May 23, 2021 Author Report Share Posted May 23, 2021 it doesnt have to go there, i could mount it to the back of the seat. i just like to be able to take the box out and use the back if needed. Link to comment Share on other sites More sharing options...
1point21gigawatts Posted May 23, 2021 Report Share Posted May 23, 2021 One more question, what type of head unit do you have? I only ask because taramps like to be around 2v preouts and you would have to tune around a 2v tilt on the tone level you listen to. Do you have a dmm and some alligator clips to go on the lead prongs? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
JonDoe Posted May 24, 2021 Author Report Share Posted May 24, 2021 i have this cheap Chinese Atoto A6, i tested the preouts at full volume before clipping with a 50hz test tone it was ~2.5v Link to comment Share on other sites More sharing options...
DallasBass91 Posted June 11, 2021 Report Share Posted June 11, 2021 On 5/22/2021 at 6:42 PM, 1point21gigawatts said: Do you ever plan on upgrading that amp to not be underpowering them subwoofers? If so, then that design is good. But if not, then you need to go bigger, like 4.75 cubic foot net and 4.25” of port width. Jacob (ceo and founder of sundown) says SA subwoofers love around 12sq” of port per cube. Thanks for that tidbit on SA specific ports 👍🏽 Link to comment Share on other sites More sharing options...
