BassMunky Posted May 27, 2021 Author Report Share Posted May 27, 2021 Bumppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
ehall8702 Posted May 27, 2021 Report Share Posted May 27, 2021 On 5/26/2021 at 11:33 AM, BassMunky said: Losing voltage???? What could be this then... Ur not loosing voltage , it's because at idle the alt outs out less than at cruising speed ( around 2k rpm), every alt has an idle rating and a higher ROM rating . Its normal, I'd suggest charging the batteries overnight on 5a or so bc if they were run low when the alt wasn't working u could be less than 100* voltage. Jut my two cents tho. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
BassMunky Posted May 27, 2021 Author Report Share Posted May 27, 2021 20 minutes ago, ehall8702 said: Ur not loosing voltage , it's because at idle the alt outs out less than at cruising speed ( around 2k rpm), every alt has an idle rating and a higher ROM rating . Its normal, I'd suggest charging the batteries overnight on 5a or so bc if they were run low when the alt wasn't working u could be less than 100* voltage. Jut my two cents tho. There brand new... Also How I know if a Diode dead or bad I put 2 in line with the sense wire upping the voltage. Been on the electricial sense wire for the alt for over 10 years Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted May 28, 2021 Author Report Share Posted May 28, 2021 Bump Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted May 29, 2021 Author Report Share Posted May 29, 2021 I have to rectifier diode online with the sense wire. How do I know if it went bad? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted May 29, 2021 Author Report Share Posted May 29, 2021 Bumppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted June 1, 2021 Author Report Share Posted June 1, 2021 Bumppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted June 3, 2021 Author Report Share Posted June 3, 2021 Bumppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
BassMunky Posted June 14, 2021 Author Report Share Posted June 14, 2021 Bumppp Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
