escottl92 Posted June 2, 2021 Report Share Posted June 2, 2021 Here it is, i have 4dr f150 no wall sub box. Five Sundown U-15" D2 subs at .8ohms powered off a Crescendo 17k. I have 320amp upgraded alt, all the Big 3. Upgraded AGM under the hood, 4 AGM in back. Voltage holds good. I compete and its my daily driver. Box is 17.5cu after displacement. 193sqin slot port tuned to 32HZ. Box is 58" x 30" x 28" I can hit a 154 but want more, any suggestions on how i can squeeze out more DB's? I have sound deadener throughout. Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 2, 2021 Report Share Posted June 2, 2021 Bigger enclosure and more port area. That’s not enough port area. That’s the main problem I see. The net volume needs to be bigger to be optimal, but can do well at 3.5 cube per like you have it, but definitely need more port area. You should be doing as way better score than what you are doing. Port positioning could possibly not be good too. Post pictures and know that that enclosure is holding you back. But I need to see it so I can tell you about positioning. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
escottl92 Posted June 2, 2021 Author Report Share Posted June 2, 2021 My port was 275 and i shrunk it to 193 to see if it would get my peak up but nope. My port is on top in back ill try to post pic Link to comment Share on other sites More sharing options...
escottl92 Posted June 2, 2021 Author Report Share Posted June 2, 2021 Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 3, 2021 Report Share Posted June 3, 2021 Walling it would be the best bet. But you could do subwoofers inverted on top and front and port driver’s side if you are content on a no wall. Let’s see them sexy subwoofers and amp in that enclosure and mix. I’d love to see. I’m thinking of buying a nendo 17k too. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
1point21gigawatts Posted June 3, 2021 Report Share Posted June 3, 2021 Inverted allows to make the enclosures width smaller to fit the side port. Side port horizontal and bottom off enclosure facing the same port height as distance from side panel on door. Because the port height is the smaller measurement of that slot port, making its measurement or close to, the ideal distance from any surface. That’s if you want optimal performance on that build as a no wall. Since subwoofers are gonna be inverted would probably put you in a wall class or advance no wall, if they want to be cool, so you mine well build a wall if you aren’t happy with your subwoofer enclosure build like it is. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.” Link to comment Share on other sites More sharing options...
escottl92 Posted June 3, 2021 Author Report Share Posted June 3, 2021 Thank you... Could i go inverted on a smaller box? Link to comment Share on other sites More sharing options...
BassMunky Posted June 3, 2021 Report Share Posted June 3, 2021 Niceeeee Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
stingray72 Posted June 15, 2021 Report Share Posted June 15, 2021 fiberglassing the inside of the enclosure will net you and extra db if done right. My brother scott snyder use to be an iasca spl record holder. Link to comment Share on other sites More sharing options...
