SkarMan Posted June 4, 2021 Report Share Posted June 4, 2021 I’m about to hook up my system to a Napa legend battery. The stock alt is 110. I get 14,4 volts currently without sub, amp, etc installed. I have the big 3 on top of that as well my mono lock skar amp output is 1500w and original plan was to run it parallel at 2 ohm at 930rms but if I run it at 1 ohm it’ll use the full 1500w what steps do I need to take while not spending a wad of cash Someone told me to upgrade the battery and I’ll be fine but I just don’t know I need outside help Link to comment Share on other sites More sharing options...
Arthur79 Posted June 4, 2021 Report Share Posted June 4, 2021 You should be ok as long as you carefully tune the amp and don't drive it into clipping. Current draw shoots sky high when a class D amp goes into clipping. Music is dynamic, meaning your current draw will have peaks and valleys. That said, you should invest in a decent volt meter and install it somewhere you can easily see/monitor. If you see your voltage continuously in the low 12s or dipping below 12 volts, you should probably start planning on upgrading to a higher output alternator. Adding a 2nd battery (close to the amplifier) or even a small SuperCap can go a long way to stiffen up your voltage, but remember that batteries and SuperCaps are power storage, not power generation - so you will need to turn the bass down from time to time in order to allow them to replenish/recharge when your voltage starts to sag. Link to comment Share on other sites More sharing options...
SkarMan Posted June 4, 2021 Author Report Share Posted June 4, 2021 Thanks man I’ll stay updated Link to comment Share on other sites More sharing options...
