RobbyMayI Posted August 21, 2021 Report Share Posted August 21, 2021 I have a single cab RAM 1500 that can only fit up to about a 2.7 cu. ft. enclosure. I currently own 2 Sundown Audio E-12 v4s with a recommendation of 1.75 cu. ft. per sub ported. Is it feasible to achieve good bass with port tuning or is it too far away from recommended specs? Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 21, 2021 Report Share Posted August 21, 2021 What are the dimensions you have to work with? Can't say for sure without knowing that. How much power are you going to be running? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
RobbyMayI Posted August 21, 2021 Author Report Share Posted August 21, 2021 6 hours ago, Triticum Agricolam said: What are the dimensions you have to work with? Can't say for sure without knowing that. How much power are you going to be running? The enclosure dimensions are 60" × 10" × 17". I'll be powering them with an Elemental Designs NiNe.1 @ 1 ohm so roughly 1200 watts. 6 hours ago, Triticum Agricolam said: Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 22, 2021 Report Share Posted August 22, 2021 Oh yeah, you can totally work within that space. Let me see if I can come up with something for you. I assume you are going to want to tune to the low 30s? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
RobbyMayI Posted August 22, 2021 Author Report Share Posted August 22, 2021 1 hour ago, Triticum Agricolam said: Oh yeah, you can totally work within that space. Let me see if I can come up with something for you. I assume you are going to want to tune to the low 30s? Preferably the low 30s. Thanks for your help! Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 22, 2021 Report Share Posted August 22, 2021 This is what I would do with that amount of space. Its ~3.2 cu ft net tuned to 32 hz with just under 50 sq in of port area. If this looks good to you I'll give you a cutsheet. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
RobbyMayI Posted August 23, 2021 Author Report Share Posted August 23, 2021 9 hours ago, Triticum Agricolam said: This is what I would do with that amount of space. Its ~3.2 cu ft net tuned to 32 hz with just under 50 sq in of port area. If this looks good to you I'll give you a cutsheet. Oh wow. That rendering came out phenomenal! Thank you so much for your efforts. I will do my best to keep you posted on my progress. 23 hours ago, Triticum Agricolam said: Oh yeah, you can totally work within that space. Let me see if I can come up with something for you. I assume you are going to want to tune to the low 30s? Preferably the low 30s. Thanks for your help! Link to comment Share on other sites More sharing options...
Never Enough Bass Posted August 25, 2021 Report Share Posted August 25, 2021 On 8/22/2021 at 11:51 AM, Triticum Agricolam said: This is what I would do with that amount of space. Its ~3.2 cu ft net tuned to 32 hz with just under 50 sq in of port area. If this looks good to you I'll give you a cutsheet. That's nice wanna help me with a box lol 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
