Mattc43 Posted September 6, 2021 Report Share Posted September 6, 2021 Hey guys I have a Toyota 2013 four runner I am just starting to work on putting in a system and it has an awesome large screen head unit that I really do not want to get rid of and replace an aftermarket hu. It has a backup camera and shows album covers and everything on the screen. My question is can I get a powered loc and still make it sound just as good as an aftermarket HU? My system will consist of 2 15s on 5k watts and single set of tweeters along with single set of 6.5s or 8's possibly. Link to comment Share on other sites More sharing options...
CorNut Posted September 6, 2021 Report Share Posted September 6, 2021 What you want is an AmpPro, it gives you a clean signal to add amplifiers or a DSP Search for part# AP4-TY11 It's not the cheapest option but it eliminates any factory radio crossovers, it leaves you with clean outputs & lets you adjust door chime volume if that goes through your radio (I'm not sure about your vehicle), plus it has a knob you can use as a bass knob for your sub amp. It's worth it's weight in gold if you want to stay with a factory look/interface. If you're going budget, check out the Dayton Audio DSP-408. I recommend doing a DSP before your amps if you're doing mids and highs as well. If you're only doing subs, it isn't as crucial. Link to comment Share on other sites More sharing options...
Mattc43 Posted September 7, 2021 Author Report Share Posted September 7, 2021 17 hours ago, CorNut said: What you want is an AmpPro, it gives you a clean signal to add amplifiers or a DSP Search for part# AP4-TY11 It's not the cheapest option but it eliminates any factory radio crossovers, it leaves you with clean outputs & lets you adjust door chime volume if that goes through your radio (I'm not sure about your vehicle), plus it has a knob you can use as a bass knob for your sub amp. It's worth it's weight in gold if you want to stay with a factory look/interface. If you're going budget, check out the Dayton Audio DSP-408. I recommend doing a DSP before your amps if you're doing mids and highs as well. If you're only doing subs, it isn't as crucial. If that’s what I gotta do then I will pay the price!! Thanks so much for the reply. That really clears things up for me but I will be adding mids/highs as well as two subs Link to comment Share on other sites More sharing options...
CorNut Posted September 8, 2021 Report Share Posted September 8, 2021 Then you absolutely want an amp pro. I'd also get a dsr-1 or similar DSP to put between the AmpPro and your amps. Link to comment Share on other sites More sharing options...
Mattc43 Posted September 8, 2021 Author Report Share Posted September 8, 2021 1 hour ago, CorNut said: Then you absolutely want an amp pro. I'd also get a dsr-1 or similar DSP to put between the AmpPro and your amps. Will the dsp take rcas from my sub amp too or just mids and highs like you said Link to comment Share on other sites More sharing options...
CorNut Posted September 8, 2021 Report Share Posted September 8, 2021 33 minutes ago, Mattc43 said: Will the dsp take rcas from my sub amp too or just mids and highs like you said The AmoPro will plug-in to your factory radio harness, it'll give you 6 outputs, 2x front, 2x rear and 2x sub. What you'll most likely want to do is use channels 1 through 4 and send them to a DSP, DSR-1 or similar, then that gives you 8 outputs to set as you see fit. Typically 2 for front, 2 for rear and 2 for subs but you have those other 2 available for whatever you want. Midbass, active components, it's a DSP so you can customize the 8 outputs to be whatever you want. You'll go factory head unit->AmpPro->DSP->4ch & monoblock Link to comment Share on other sites More sharing options...
Arthur79 Posted September 8, 2021 Report Share Posted September 8, 2021 The Amp Pro will give you clean RCA's out of the head unit. You would take those pre-amps into a DSP (like the DSR-1 or an Audio Control DM-608). The DSP will allow you to do things like time alignment, level adjustment and of course something like a 31 band adjustable EQ for each channel. You can either use a remote nob with your DSP to control the sub amp level - or just use the nob that comes with your bass amp. Link to comment Share on other sites More sharing options...
Mattc43 Posted September 8, 2021 Author Report Share Posted September 8, 2021 10 hours ago, CorNut said: The AmoPro will plug-in to your factory radio harness, it'll give you 6 outputs, 2x front, 2x rear and 2x sub. What you'll most likely want to do is use channels 1 through 4 and send them to a DSP, DSR-1 or similar, then that gives you 8 outputs to set as you see fit. Typically 2 for front, 2 for rear and 2 for subs but you have those other 2 available for whatever you want. Midbass, active components, it's a DSP so you can customize the 8 outputs to be whatever you want. You'll go factory head unit->AmpPro->DSP->4ch & monoblock Ok so from the dsp I will have 4 rca inputs (2 going to 4 channel amp and 2 going to sub amp?) Link to comment Share on other sites More sharing options...
CorNut Posted September 8, 2021 Report Share Posted September 8, 2021 How many out you have depends on which DSP you choose. All 3 DSP's mentioned in this thread have 8 outputs, hence, why I said you'd have 2 leftover. If you don't understand a DSP/it confuses you, get the AmpPro and call it a day. I feel like you're confused, regardless of how much I explain it. An AmpPro will let you connect a 4-ch mids amp and also a sub amp. That's probably your best bet, just use the crossovers on the amps or on your head unit. Link to comment Share on other sites More sharing options...
Mattc43 Posted September 8, 2021 Author Report Share Posted September 8, 2021 32 minutes ago, CorNut said: How many out you have depends on which DSP you choose. All 3 DSP's mentioned in this thread have 8 outputs, hence, why I said you'd have 2 leftover. If you don't understand a DSP/it confuses you, get the AmpPro and call it a day. I feel like you're confused, regardless of how much I explain it. An AmpPro will let you connect a 4-ch mids amp and also a sub amp. That's probably the m your best bet, just use the crossovers on the amps or on your head unit. Ok I’ll just get the amp pro. Thanks Link to comment Share on other sites More sharing options...
