Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 Yea I mean I twisted the wire tight and it was still a tight fit 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Liljxthexripper Posted September 11, 2021 Author Report Share Posted September 11, 2021 2 minutes ago, Never Enough Bass said: Yea I mean I twisted the wire tight and it was still a tight fit i guess im stumbled here cause doing research im not sure if my 12 gauge together (9 gauge) will be able to hold up to the output of the sia 3500. as ive been told even at a 2 ohm load (because mine are dv2 so ill wired them up to pull 2 at amp) the output is still supposed to be about 3500. im looking to realistically push the full 1500 ish (i understand its not technically rms, but i want to make sure my wire will hold peak power) to each sub. itll technically be under a 4 foot run Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 It should I have the sia 3500 on 2 Sa v2 d4's as long as it's ofc u should be good the terminals on the amp and the subs are only oversized 8 gauge wire terminals 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 As u see I'm at 1 ohm but that's before ohm rise u can't defeat that 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 And even if u have to trim some off just make sure what u trim off is pushed up tight to the terminal and it'll still flow the current or use the reducers like u were saying 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Dafaseles Posted September 11, 2021 Report Share Posted September 11, 2021 3 hours ago, Liljxthexripper said: i appreciate the quick response, but do you know the actual size of the stock terminals? that way i can buy the correct reducer lol. Looking around the net, everything I see says 8 awg. I haven't personally owned any though, so this is just information I've found 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 1 minute ago, Dafaseles said: Looking around the net, everything I see says 8 awg. I haven't personally owned any though, so this is just information I've found Proud owner right here lol 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Liljxthexripper Posted September 11, 2021 Author Report Share Posted September 11, 2021 ill take a pic in a few. combining my 12 gauge wires now and going to run it at 1000 watts combined for now till i get my alternator in, and anyways and itll be a good break in. i thought sky high was supposed to be only about 25% oversized but no. this 8 gauge is like 5 gauge wire because the 2 12 gauge look to be perfect size for the terminals. i was splitting and electrical taping it up so the wire was still contacting the terminal but it was just too sketchy for me to feel good about it. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 11, 2021 Report Share Posted September 11, 2021 Lol yea I got mine around 3000 watts rn waiting on my dd1+ and cc1 so I can turn it up I'm also waiting to get my custom box built 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Liljxthexripper Posted September 11, 2021 Author Report Share Posted September 11, 2021 so even my twist 12 gauge wont fit. the terminal spring cap is 12 gauge, while the inside is actually 8 gauge. legit. these were new in box. already got my custom box, port was 3 inches from bottom so raised it to be about 5 but kept port length for tuning. already about 1400 in with the 0 gauge from gp. itll be clean eventually. im very dissappointed with these terminals. no wonder the guy i got my r3s from had custom 4 gauge terminals on it lol if i kept both i couldve switched but sold my other that i made a house sub out of just before i started this. ima just hope these wires stay in. Link to comment Share on other sites More sharing options...
