CMcLane816 Posted September 20, 2021 Author Report Share Posted September 20, 2021 Appreciate the help ! That makes total sense, the amp will draw what it needs, didnt even think about that lol. Yes, I will be using the solid side of block for 2x 2/0 runs, other side dual power to cab 45, and single run 4ga to skar amp. I emailed CAB and they got back really fast. Amp calls for 400 amp fusing, I will use 200 on the dual inputs ! and 400-450 under the hood. Thanks again ! Will check back if I have any other ?'s Link to comment Share on other sites More sharing options...
Dafaseles Posted September 20, 2021 Report Share Posted September 20, 2021 3 hours ago, CMcLane816 said: Appreciate the help ! That makes total sense, the amp will draw what it needs, didnt even think about that lol. Yes, I will be using the solid side of block for 2x 2/0 runs, other side dual power to cab 45, and single run 4ga to skar amp. I emailed CAB and they got back really fast. Amp calls for 400 amp fusing, I will use 200 on the dual inputs ! and 400-450 under the hood. Thanks again ! Will check back if I have any other ?'s Always bud! You could always do a build log as well. We here always like to watch a good install! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Donp757 Posted September 22, 2021 Report Share Posted September 22, 2021 So i just did my first “bigger system” too, on my main run from front to back battery i fused up front and in the back. What do you think about that? Also realized i under fused my 2/0 wire at 300A had not ben a problem yet my alt is only 200. But will be upgrading that in the near future. And will get right size fuses Link to comment Share on other sites More sharing options...
