Jeremy009 Posted September 26, 2021 Report Share Posted September 26, 2021 Faulty Equipment or Faulty Installation Hey guys, i need some help. I brought equipment new about a month ago and only had time to install it today. Car is a nissan tiida sedan and a front stage only was done in stereo. Gains was set with the onboard clipping indicator on amp. What was used- jl audio jd 400.4 new Pair Resilient sounds 6.5 75rms each 4ohm speaker new Pair of silk dome tweeters 50rms each new Nvx 0gauge ofc silver tinned Used pioneer 80prs from my previous install which had no issues known. Xfire RCAs new. Ofc 16 gauge for speaker runs Whats going on: system powers on fine and plays, once i reach half volume or above on the head unit the mids and highs cuts on and off or shorts and the amp goes into protect. I used a seat belt bolt in the back (sanded) for ground for the amp. When i set the gains playing a 1000hz tone without the speakers connected it did not go into protect, Only when playing music. The deck isnt cutting on and off, it remains on like normal when the shorting starts. Any assistance is appreciated. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted September 26, 2021 Report Share Posted September 26, 2021 Go over all your wires again 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
itsjeremy87 Posted September 26, 2021 Report Share Posted September 26, 2021 Yeah, that sounds like a wiring issue all day. Check every connection. Link to comment Share on other sites More sharing options...
Jeremy009 Posted September 26, 2021 Author Report Share Posted September 26, 2021 Guys,i edited the post and added some more details. Please read it over and tell me if its still the wiring Link to comment Share on other sites More sharing options...
stingray72 Posted September 26, 2021 Report Share Posted September 26, 2021 dont ground to the seat belt bolt find somewhere better. Link to comment Share on other sites More sharing options...
Dafaseles Posted September 26, 2021 Report Share Posted September 26, 2021 Are you using a passive crossover? 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Jeremy009 Posted September 27, 2021 Author Report Share Posted September 27, 2021 1 hour ago, Dafaseles said: Are you using a passive crossover? Nope. Using the crossover on the 80prs Link to comment Share on other sites More sharing options...
Jeremy009 Posted September 27, 2021 Author Report Share Posted September 27, 2021 I did some more troubleshooting...it only goes into protect when my doors are closed. When there both open it plays fine Link to comment Share on other sites More sharing options...
itsjeremy87 Posted September 27, 2021 Report Share Posted September 27, 2021 Is your wiring routed so it could possibly getting pinched somehow or somwhere (i.e. door jamb, trim etc... when the doors are closed). Still seems wiring. Bad wire. Open wire, Loose connection. Something along those lines when you close your doors. Try one door at a time and see if you can isolate it to one door and re check that sides wiring. Link to comment Share on other sites More sharing options...
Jeremy009 Posted September 27, 2021 Author Report Share Posted September 27, 2021 8 minutes ago, itsjeremy87 said: Is your wiring routed so it could possibly getting pinched somehow or somwhere (i.e. door jamb, trim etc... when the doors are closed). Still seems wiring. Bad wire. Open wire, Loose connection. Something along those lines when you close your doors. Try one door at a time and see if you can isolate it to one door and re check that sides wiring. I tried. It happens with both doors. When both are open,it plays fine. The wire it ran alongside the grommet. Is there any way to easily run it through the grommet? Link to comment Share on other sites More sharing options...
