Music shorting and amp going into protect
24 minutes ago, itsjeremy87 said:
I wouldnt be much help without seeing what grommet your talking about. The rubber boot that houses the doors incoming electrical? Usually they pop right out and you can run your  wires along the same wiring bundle, following factory routes.
Will that fix the issue?
