*NEW BUILD* / *First "bigger" Build* 2009 GMC Sierrra SUB BUILD
 He is loving the smart 5k. He said its super efficient only needs 12.6v for max output. Obviously windy af. I was sketched that you only have 1 Rca in, but I guess that doesn’t matter. He said you can play at max volume for a minute or 2 then you gotta let subs cool off for a minute, but 80-90% sound amazing and can play all day.
  • Replies 43
  • Created
  • Last Reply
Yeah, that amp is too much for those subs and/ or he has his gain up too much and he's clipping if he has to let the subs "cool down".
Regardless, as long as you set your gain correctly, you'll be fine.
1 RCA doesn't matter, is a mono signal.
One of those things I've read over and over again is that the damping factor of an amplifier is a huge contributor to how well the amplifier can keep control of the sub below box tuning. So maybe that little tidbit of info can help with your decision
He isn’t clipping them, but it’s about all they can handle tuned right before clipping when they are full tilt. 80-90% volume and they sound great and are fine. I’ve seen 6200 watts on the dyno from the smart 5k at 2ohm, so it’s combatting rise like crazy and performing like a 8k amp. I thinking dampening factor is really similar on each amp 150-200 range
  • 3 weeks later...
Little update.
All runs are done to the back and purchased a smart 5k. Should of had everything installed but my boy got Covid that’s building my box. So has been delayed, probably
next couple weeks will be done. He’s all good now so just gotta find some time.
Also, wish I would have sheathed my first 2 power runs ehh, may get some loom if I don’t fell like re running it. Now just deciding on if I want a another d3400 to have 2x under hood, or some lithium. Hmmmm
50 minutes ago, CMcLane816 said:
Little update.
Looking good so far! I don't care what anyone says, I miss my vortec 5.7 man!
1 hour ago, CMcLane816 said:
Got prv dsp in and the box is done and came out so bad ass I love it ! Not sure if video will upload I’ll throw up some pics. Should install everything around next weekend.
IMG_0480.MOV
That blue came out sick!
  • Who's Online   1 Member, 0 Anonymous, 333 Guests (See full list)
