CMcLane816 Posted December 21, 2021 Author Report Share Posted December 21, 2021 He is loving the smart 5k. He said its super efficient only needs 12.6v for max output. Obviously windy af. I was sketched that you only have 1 Rca in, but I guess that doesn’t matter. He said you can play at max volume for a minute or 2 then you gotta let subs cool off for a minute, but 80-90% sound amazing and can play all day. Link to comment Share on other sites More sharing options...
CMcLane816 Posted December 21, 2021 Author Report Share Posted December 21, 2021 16 minutes ago, BassMunky said: Looks pretty clean bro Appreciate it man ! Can’t wait to get it done, then time for the front doors 4x8s / 2x 3.5 tweets per door. Thinking all skar on a jp23x4 channel. Link to comment Share on other sites More sharing options...
Dafaseles Posted December 22, 2021 Report Share Posted December 22, 2021 33 minutes ago, CMcLane816 said: He is loving the smart 5k. He said its super efficient only needs 12.6v for max output. Obviously windy af. I was sketched that you only have 1 Rca in, but I guess that doesn’t matter. He said you can play at max volume for a minute or 2 then you gotta let subs cool off for a minute, but 80-90% sound amazing and can play all day. Yeah, that amp is too much for those subs and/ or he has his gain up too much and he's clipping if he has to let the subs "cool down". Regardless, as long as you set your gain correctly, you'll be fine. 1 RCA doesn't matter, is a mono signal. One of those things I've read over and over again is that the damping factor of an amplifier is a huge contributor to how well the amplifier can keep control of the sub below box tuning. So maybe that little tidbit of info can help with your decision 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
CMcLane816 Posted December 22, 2021 Author Report Share Posted December 22, 2021 33 minutes ago, Dafaseles said: Yeah, that amp is too much for those subs and/ or he has his gain up too much and he's clipping if he has to let the subs "cool down". Regardless, as long as you set your gain correctly, you'll be fine. 1 RCA doesn't matter, is a mono signal. One of those things I've read over and over again is that the damping factor of an amplifier is a huge contributor to how well the amplifier can keep control of the sub below box tuning. So maybe that little tidbit of info can help with your decision He isn’t clipping them, but it’s about all they can handle tuned right before clipping when they are full tilt. 80-90% volume and they sound great and are fine. I’ve seen 6200 watts on the dyno from the smart 5k at 2ohm, so it’s combatting rise like crazy and performing like a 8k amp. I thinking dampening factor is really similar on each amp 150-200 range Link to comment Share on other sites More sharing options...
CMcLane816 Posted December 22, 2021 Author Report Share Posted December 22, 2021 I’m thinking smart 5k if I wanna push the limit of the vxfs, rp45 would be easier on them Link to comment Share on other sites More sharing options...
CMcLane816 Posted January 11, 2022 Author Report Share Posted January 11, 2022 Little update. All runs are done to the back and purchased a smart 5k. Should of had everything installed but my boy got Covid that’s building my box. So has been delayed, probably next couple weeks will be done. He’s all good now so just gotta find some time. Also, wish I would have sheathed my first 2 power runs ehh, may get some loom if I don’t fell like re running it. Now just deciding on if I want a another d3400 to have 2x under hood, or some lithium. Hmmmm Link to comment Share on other sites More sharing options...
Dafaseles Posted January 11, 2022 Report Share Posted January 11, 2022 50 minutes ago, CMcLane816 said: Little update. All runs are done to the back and purchased a smart 5k. Should of had everything installed but my boy got Covid that’s building my box. So has been delayed, probably next couple weeks will be done. He’s all good now so just gotta find some time. Also, wish I would have sheathed my first 2 power runs ehh, may get some loom if I don’t fell like re running it. Now just deciding on if I want a another d3400 to have 2x under hood, or some lithium. Hmmmm Looking good so far! I don't care what anyone says, I miss my vortec 5.7 man! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
CMcLane816 Posted January 16, 2022 Author Report Share Posted January 16, 2022 Got prv dsp in and the box is done and came out so bad ass I love it ! Not sure if video will upload I’ll throw up some pics. Should install everything around next weekend. IMG_0480.MOV Link to comment Share on other sites More sharing options...
Dafaseles Posted January 16, 2022 Report Share Posted January 16, 2022 1 hour ago, CMcLane816 said: Got prv dsp in and the box is done and came out so bad ass I love it ! Not sure if video will upload I’ll throw up some pics. Should install everything around next weekend. IMG_0480.MOV That blue came out sick! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
BLUE COLLAR MISFIT Posted January 17, 2022 Report Share Posted January 17, 2022 7 hours ago, Dafaseles said: That blue came out sick! That finish on that box came out bad ass man. I can’t wait to get started on mine. Link to comment Share on other sites More sharing options...
