Audiohz Posted October 11, 2021 Report Share Posted October 11, 2021 I have two sundown U12’s I contacted Bobby gately on the 2 12’s 3.25 shorty enclosure, he said would work great . My only question I forgot to ask is power handling. I know sealed box bigger less power handling smaller more handling. Does same apply to ported? Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 11, 2021 Report Share Posted October 11, 2021 I'm building a box for 2 u 12's right now and my box is like 3.80 cu ft I got a 3500 rms amp right now might need to upgrade but sealed u need more power ported u need less power 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
CorNut Posted October 11, 2021 Report Share Posted October 11, 2021 The same logic applies with ported too. It'll be hard to overpower those regardless, just make sure they're getting a clean signal Link to comment Share on other sites More sharing options...
Audiohz Posted October 11, 2021 Author Report Share Posted October 11, 2021 10 minutes ago, CorNut said: The same logic applies with ported too. It'll be hard to overpower those regardless, just make sure they're getting a clean signal Doing a salt 4K going to set with a dd1 -5db or -7.5bd not sure yet Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 11, 2021 Report Share Posted October 11, 2021 That would be nice I have the sia 3500 been thinking about going to the salt 4k 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Audiohz Posted October 12, 2021 Author Report Share Posted October 12, 2021 20 hours ago, Never Enough Bass said: I'm building a box for 2 u 12's right now and my box is like 3.80 cu ft I got a 3500 rms amp right now might need to upgrade but sealed u need more power ported u need less power After displacement I’m calculating 1.44 per sub with the gately enclosure. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 12, 2021 Report Share Posted October 12, 2021 Yea mine is 3.80 after displacement 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
