Mason Denk Posted October 15, 2021 Report Share Posted October 15, 2021 I'm working on a Skar Audio ZVX 18, and I have all other specs down. KickerU is giving me a square port, instead of a rectangular one. The square port is 8.86in by 8.86. Is there a way I could change this port to a rectangular one, without changing the tuning frequency? Tuning is 30hz, as requested by owner. Thanks to all who answer, and have a good rest of your day! -Mason Link to comment Share on other sites More sharing options...
Dafaseles Posted October 15, 2021 Report Share Posted October 15, 2021 You can change the shape without effecting tuning. As long as you keep the desired amount of square inches of port opening. The length of the port mostly determines the tuning frequencies 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 15, 2021 Report Share Posted October 15, 2021 So does width and height 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Dafaseles Posted October 15, 2021 Report Share Posted October 15, 2021 1 hour ago, Never Enough Bass said: So does width and height You're right, it does. I'm sorry 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 15, 2021 Report Share Posted October 15, 2021 17 minutes ago, Dafaseles said: You're right, it does. I'm sorry He's gonna have to compensate somewhere to make it right if he goes higher he's either gonna have to be not as wide or not as long his choice 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
CstrokerV Posted October 16, 2021 Report Share Posted October 16, 2021 Just keep the area the same … times the 2 together then play with the dimensions till you get the same as the 2 that was times together and keep the length just for an example of mine was 4X4 that’s 16 so I could do a 8x2 and it would keep the length the same my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 16, 2021 Report Share Posted October 16, 2021 This isn't the same and I hope it works but I made my design 2in deeper so I made my port 2in longer 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
