Never Enough Bass Posted October 21, 2021 Report Share Posted October 21, 2021 Lol well sounds like u deserve an upgrade my double din is only like 350 or something at best buy 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
PooThenPee Posted October 21, 2021 Author Report Share Posted October 21, 2021 21 hours ago, Never Enough Bass said: Lol well sounds like u deserve an upgrade my double din is only like 350 or something at best buy I looked at them today and they are surprisingly cheap! I may go that route. Link to comment Share on other sites More sharing options...
PooThenPee Posted October 21, 2021 Author Report Share Posted October 21, 2021 So I havent done any of the big 3 or other upgrades but I followed a video on how to set gains with the DMM and with following that perfectly, setting vol to 3/4, all eq and settings flat and off and dmm leads in speaker outputs on amp. With a 40 hz tone and the gain all the way up it only got to 12 volts. I need 31ish. I think the line booster is a must. As well as the other things. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 21, 2021 Report Share Posted October 21, 2021 24 minutes ago, PooThenPee said: So I havent done any of the big 3 or other upgrades but I followed a video on how to set gains with the DMM and with following that perfectly, setting vol to 3/4, all eq and settings flat and off and dmm leads in speaker outputs on amp. With a 40 hz tone and the gain all the way up it only got to 12 volts. I need 31ish. I think the line booster is a must. As well as the other things. Just a new headunit is all u need u wasn't measuring something right 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 21, 2021 Report Share Posted October 21, 2021 25 minutes ago, PooThenPee said: I looked at them today and they are surprisingly cheap! I may go that route. They are pretty cheap I have the avh 521ex 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
PooThenPee Posted October 22, 2021 Author Report Share Posted October 22, 2021 20 minutes ago, Never Enough Bass said: They are pretty cheap I have the avh 521ex Appreciate it, I'm looking at them now Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 22, 2021 Report Share Posted October 22, 2021 Yea your not measuring your voltage right either u have to measure the speaker terminal on the amp 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
PooThenPee Posted October 22, 2021 Author Report Share Posted October 22, 2021 9 minutes ago, Never Enough Bass said: Yea your not measuring your voltage right either u have to measure the speaker terminal on the amp That is what I did. Sorry if I didnt state it clearly. I didn't put in the speaker wire to the sub and put the leads in the amp speaker terminals. Also, I am seeing that the RCA preouts on these new headunits are also 2V... Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 22, 2021 Report Share Posted October 22, 2021 The 1 I have is 4v u just have to look 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 22, 2021 Report Share Posted October 22, 2021 MVH-S522BS this is 4v pre outs 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
