killerc998 Posted October 19, 2021 Report Share Posted October 19, 2021 Sup yall. Got 4 i series 12s (old model 300rms) coming, will be powered with 1500rms. Box im looking at doing is 7 cubes after displacement with 100 square inch of port? Port will be slot Any issues yall see, or recommendations it will be going in to a 99 burb. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 19, 2021 Report Share Posted October 19, 2021 Issue is might be a little small and the other issue is u haven't built it yet 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
killerc998 Posted October 20, 2021 Author Report Share Posted October 20, 2021 Ya its on the smaller side. The new i series are 500 rms and min is 1.5 cubes per sub, recommended is 2 per sub. Since these are 300 rms i figure its 1.35/1.4 on small size. Im actually thinking the box will be about 7.5 after displacement. Subs will be slightly overpowered, so a lil small should work. Subs will be here friday. Link to comment Share on other sites More sharing options...
killerc998 Posted October 22, 2021 Author Report Share Posted October 22, 2021 So doing some more math, box is 9.8 gross, 7.5 net with 116.25 square inch of port. Only question i got is on the port. I got plenty of sq in, its however 46.5x2.5. With the subs calling for a min of 22 sq in and im well above that, do yall think the narrow height will be an issue. The port m/s is around 15 by win isd. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 22, 2021 Report Share Posted October 22, 2021 The port is gonna be as tall as your box by 2.5in wide and 46.5in long if that's what winsld calculated it should be good I thing it should graph your air speed and everything 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
killerc998 Posted October 25, 2021 Author Report Share Posted October 25, 2021 Winisd showed air speed under 20ms but if you add a generic parameter to mimic a car it shoots it above 35 ms. Should i make the ms below 20 with the car parameter or just aim for 20 ms. This is going to be a musical box not a spl. Im going to keep it to 33/36 hrz. I could keep the box as is, but i like building boxes that are ideal. Link to comment Share on other sites More sharing options...
killerc998 Posted November 7, 2021 Author Report Share Posted November 7, 2021 So box ended up being 9.88932 gross, 7.7 net tuned to 35 hrz. Port is 7.5"x15", .75" external port that will be half rounded off. Internal port will be rounded. Link to comment Share on other sites More sharing options...
Dafaseles Posted November 7, 2021 Report Share Posted November 7, 2021 Can't wait to see it in the burban! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
killerc998 Posted November 23, 2021 Author Report Share Posted November 23, 2021 Thought this was an interesting picture. Was test fitting width. Port has been round over rounded the port sides, now time to glue the rest of the box together. Link to comment Share on other sites More sharing options...
Dafaseles Posted November 23, 2021 Report Share Posted November 23, 2021 1 hour ago, killerc998 said: Thought this was an interesting picture. Was test fitting width. Port has been round over rounded the port sides, now time to glue the rest of the box together. It's coming along! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
