SwoleCole Posted October 23, 2021 Report Share Posted October 23, 2021 Is it possible to wire 2 door speakers in separate doors together at the amp? or right before it? Instead of having to wire one door speaker to the other door speaker Link to comment Share on other sites More sharing options...
Never Enough Bass Posted October 23, 2021 Report Share Posted October 23, 2021 U can it'll change the ohms tho 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Dafaseles Posted October 23, 2021 Report Share Posted October 23, 2021 41 minutes ago, SwoleCole said: Is it possible to wire 2 door speakers in separate doors together at the amp? or right before it? Instead of having to wire one door speaker to the other door speaker What exactly is your plan? Can you wire them together in series or parallel? Absolutely. If I knew your plan, I could help better 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
