Apollonick Posted November 6, 2021 Report Share Posted November 6, 2021 Hello y'all I have just a quick question regarding my system. It's 2 sa-12 dvc 4 subs wired separately with final coming out of the wires at 2 ohm's each I also have a sae2000d amp with 4 terminals 2 positive 2 negative will the amp see 4 ohms with both subs wired up or will it be better to wire both up to 1 ohm final and then hook onto one set of terminal on the amp. Link to comment Share on other sites More sharing options...
Dafaseles Posted November 6, 2021 Report Share Posted November 6, 2021 If each set of wires coming from each sub reads 2 ohm, the amp will see 1 ohm. That's perfectly fine. Even though it has 2 sets of speaker inputs, they are connected internally, so it's still a single channel amplifier. There are 2 sets for ease of installation. Nothing more. If you connect them, have a final 1 ohm impedance for both, and only connect the 1 set of speaker wires, it'll be the same outcome. Either or. It's up to you 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
