Zim819 Posted January 19, 2022 Report Share Posted January 19, 2022 I’m trying to design a box for my two 15 Incriminator audio lethal injections. I’ve designed the box on sub box pro and modeled it on winisd. To be honest I’m not 100% sure what all I’m looking for. my -f3 is 28.61 hz My rear port air velocity is between 18 and 19. Ideal is below 18? I’m wanting to make sure everything’s ok before I start building boxes. My plan is to build two single boxes and stack them and glue them together like one big box. I’ve kept everything for the box with in factory specs of recommended and maximum. This will be in my daily driver. Any direction or advice would be much appreciated Subwoofer box 1/13/22 2nd try Link to comment Share on other sites More sharing options...
Joe X Posted January 19, 2022 Report Share Posted January 19, 2022 Color change: I’m trying to design a box for my two 15 Incriminator audio lethal injections. I’ve designed the box on sub box pro and modeled it on winisd. To be honest I’m not 100% sure what all I’m looking for. my -f3 is 28.61 hz My rear port air velocity is between 18 and 19. Ideal is below 18? I’m wanting to make sure everything’s ok before I start building boxes. My plan is to build two single boxes and stack them and glue them together like one big box. I’ve kept everything for the box with in factory specs of recommended and maximum. This will be in my daily driver. Any direction or advice would be much appreciated Link to comment Share on other sites More sharing options...
Zim819 Posted January 19, 2022 Author Report Share Posted January 19, 2022 Thanks, I’m not sure why the font was black nor could I figure out how to change it Link to comment Share on other sites More sharing options...
Joe X Posted January 19, 2022 Report Share Posted January 19, 2022 No problem, you did the manufacturer spec and that's fine, what you don't mention is what's the vehicle, why two boxes and what you are not liking or the question you want answered. Link to comment Share on other sites More sharing options...
Zim819 Posted January 19, 2022 Author Report Share Posted January 19, 2022 I tried copying and pasting the manufacture info but it wouldn’t save. it’ll be in 2011 ford e250 which is my work/personal vehicle. Id like to do two separate boxes and join them as one. Because I’d like to have my port in the center, instead of one side or the other. I plan to have the box between the two front seats standing up the the front of my cab. like in the picture. I already know the port looks like crap in the picture. I rushed. It was a learning lesson. I’m just wanting to make sure the box and design are good and not going to damage my subs. Link to comment Share on other sites More sharing options...
BassMunky Posted January 19, 2022 Report Share Posted January 19, 2022 How much is for a sheet of wood now? Mdf and Baltic birch? Heard prices doubled. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
Zim819 Posted January 19, 2022 Author Report Share Posted January 19, 2022 Depends on where you go. I’ve seen MDF $45-$50 a sheet and birch $90+ I’ll definitely be saving to purchase birch. Link to comment Share on other sites More sharing options...
Joe X Posted January 19, 2022 Report Share Posted January 19, 2022 5 hours ago, Zim819 said: I tried copying and pasting the manufacture info but it wouldn’t save. it’ll be in 2011 ford e250 which is my work/personal vehicle. Id like to do two separate boxes and join them as one. Because I’d like to have my port in the center, instead of one side or the other. I plan to have the box between the two front seats standing up the the front of my cab. like in the picture. I already know the port looks like crap in the picture. I rushed. It was a learning lesson. I’m just wanting to make sure the box and design are good and not going to damage my subs. As long as your power and subsonic filter are set to reasonable levels and there is no clipping, it's hard to damage your subs in a manufacturer suggested box spec so that should not concern you that much. Besides the obvious lack of port area of the box in the pic, in a van likely the only way of getting loud is to build a wall behind the first seat row, otherwise you will get mediocre results. Link to comment Share on other sites More sharing options...
Zim819 Posted January 20, 2022 Author Report Share Posted January 20, 2022 Ok thank you. Yes everything will be set correctly. I will be purchasing an oscilloscope to set my gains and make sure there’s no clipping. I thought about a wall, but honestly unsure. I had madea post before about joining boxes and having a common center port. I had designed a couple cabinets on sub box pro. But unsure if there quality. or if there correct. https://subbox.pro/en/b/8jJY3JVh3 https://subbox.pro/en/b/JYQ2KUuYP Link to comment Share on other sites More sharing options...
