TC Sounds LMS Ultra C-Pillar Wall
27 minutes ago, jnasty said:
Thanks brotha!! I didn't realize how much stuff I was trying to cram where the back seats were. Definitely looks cleaner without the batteries next to the amps
You definitely maximized the space in there. Looks very clean!
On 6/9/2022 at 10:22 AM, jmanjr82 said:
That is going to be sick! Never seen the Duracell cap wraps just durabass that look like Duracell batteries. Did you make those or buy them? Cost? Site? Can't wait to see this done!!
Thanks man! I got them from LoudAF.net (LAF). In the comment section I write "Duracell" wraps. I did wo separate orders a few months apart before I added my other 80ah. Had no problems with either order. Honestly,  a little pricey at $90 for the 12 cells. But the guy has a unique product & ya gotta support the little guys too
Vehicle: 2002 Ford Escape
Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps
Head Unit: Apple iPad Hi-Res Passthrough Topping d10s
Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0
Sub Stage: (2) TC Sounds LMS Ultra 5400 18"
Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE
Processing: Helix DSP Pro W/ Dash Mounted Director
Did a little sealing from the rear this afternoon. foamed all rear body panels, between body & plastics then made shims for between plastics and box. Currently waiting for cure then ill work on the beauty panel. it'll be a mix of black suede and a forged carbon vinyl wrap
Compress_20220611_125527_7786
Compress_20220611_125528_8176 Compress_20220611_125528_8032 Compress_20220611_125527_7632
Compress_20220611_125527_7460 Compress_20220611_125527_7312
Looking really nice!
If you don't mind me asking, what foam did you use? I'm doing something similar in a buddies car
Thanks! I used great stuff big gap filler.. I made sure I covered all body panels with painters tape though, just in case the plastic needs to come off for any reason
I'm going to have to look into that for sure! Although.... we where doing something similar... the C pillar wall turned into a B pillar wall because of hight restrictions in his crossover. It's built very funky!
Give it a shot! It definitely helped BIG TIME
So I mounted them quick to get an idea, fed them from a b2 rage 2500.1 at 2ohm so they saw 2k.. Honestly thought it'd be a touch louder on 2k. Definitely over 150db for sure though (comparing to my older systems which I've metered). Either way, when all said & done they'll see 8k.. slightly more power lol. Did a little trim work & wrapped the amps in a vinyl. The beauty panel upper portion around the port will also be wrapped in the forged carbon vinyl & the lower half around the subs will be black suede. I'll have trouble wiring the amps as it's REAL tight. We'll see 🤷🏻
20220612_181719 20220613_190519
20220615_201058
20220615_201611
20220616_171411
20220617_181345
20220617_181407
20220615_201058
20220615_201611
20220616_171411
20220617_181345
20220617_181407
That's good lookin' right there!
  • Who's Online   0 Members, 0 Anonymous, 1162 Guests (See full list)
