TC Sounds LMS Ultra C-Pillar Wall
More slow progress..
-Molded the beauty panel into the Cpillar with "kitty hair" & wrapped in suede- 1st time using the stuff, wayyy better than bondo
- built amp rack as 1 piece, painted with krylon stone spray paint... yeahhh, I know I  took the easy route but no way was I gonna be able to wrap it successfully 🤣
- started lithium rack in the rear, 80ah & 500 farad on each side, big distro in the middle
20220625_163743
20220625_162400
20220625_160752
20220626_183638
20220626_180814
20220628_175038
20220628_175042
20220628_190340
20220628_190351
20220628_195234
20220629_182828
20220701_181335
20220701_181358
20220701_181525
20220626_150106
20220626_152058
20220626_160151
20220701_184630
20220701_184641
Vehicle: 2002 Ford Escape
Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps
Head Unit: Apple iPad Hi-Res Passthrough Topping d10s
Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0
Sub Stage: (2) TC Sounds LMS Ultra 5400 18"
Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE
Processing: Helix DSP Pro W/ Dash Mounted Director
20220625_163743
20220625_162400
20220625_160752
20220626_183638
20220626_180814
20220628_175038
20220628_175042
20220628_190340
20220628_190351
20220628_195234
20220629_182828
20220701_181335
20220701_181358
20220701_181525
20220626_150106
20220626_152058
20220626_160151
20220701_184630
20220701_184641
I think that actually looks really good with the stone paint! Looking damn good all around!
I would have to agree, I like the Stone Paint! Gives me an idea for my next update. This build is lookin really good, can't wait to see the finished system!
Thanks dudes! it's growing on me, just wrapped the mdf floorboard with suede and it's flows nicely
Finally started one side of the lithium rack in the back.. had to drill&tap some holes in the links so I can mount from the backside. Made out of 1/4 cast acrylic & stainless fasteners. Make a real rookie mistake & put the assembled lithium bank on my table saw table... the screws in the back side of the mdf shorted out and made a bit of a fire & melted the screws.. not too much damage though
20220707_184809
20220707_191813
20220707_192050
20220707_200239
20220710_090005
20220710_110758
20220710_124302
20220710_173039
20220710_173047
20220710_173530
20220710_173812
20220710_182914
20220710_183411
20220710_191612
20220710_194946
On 7/10/2022 at 10:56 PM, Dafaseles said:
Looking good! Those bars you made are looking nice and clean as well. I like those a lot!
Thanks! But I didn't make the bars, toolmaker Metalworkz made them. I just had to tap some holes in the links to mount
Mounted the one side of the lithium, made the trim panels match the contour or the plastics & wrapped. Also started the pillars.. my 1st time doing pillars so take it easy on me
20220715_160840
20220715_160835
20220715_190215
20220715_190208
2022-07-16_03-20-10
Had to cover the hole from my IB setup - all power & ground wire are routing through this
20220715_155004
20220716_094626
20220716_102347
20220716_114559
20220716_121530
20220716_121412
20220716_134513
2022-07-16_03-07-15
  • 1 month later...
Not a ton accomplished over the past few weeks..
Almost complete with a pillars. Totally underestimated the Fab required.. these are the 1st time I've tried to make pillars in my life. Flocked them, still need to cover the grab handles. Also need to make the cloth cover with a MDF ring, the 3d printed ring warped BIGTIME in the sun
20220722_163336
20220724_112931
20220726_162439
20220803_181442
20220825_094252
20220825_094400
Assembled the 3rd & 4th banks of lithium & supercaps. Mounted in the rear and started deciding where to place the distribution block
20220803_165749
20220807_100211
20220808_184534
20220809_190333
20220809_190717
Terminated belden cat6a to WBT ends(legitimate rca's - not the eBay specials lol) ran cat6 & rj45 to amps & processor in center console
20220825_095737
20220729_150546
20220801_160018
20220801_180622
20220825_095723
20220825_095718
Installed arc 6.0s in the door
20220813_092123
20220813_105523
20220813_110515
  • Who's Online   1 Member, 0 Anonymous, 1547 Guests (See full list)
