Never Enough Bass Posted April 6, 2022 Report Share Posted April 6, 2022 Really those amps do not like voltage drop at all 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Never Enough Bass Posted April 6, 2022 Report Share Posted April 6, 2022 On 3/22/2022 at 10:27 AM, Thompson358 said: I will try doing that again when I get home but that’s what my friend did for me lastnight and I just can’t get it to hit any harder without the clip light blinking do you think my SIA3500.1 could be messed up I’m super worried about it because I don’t have the money to buy another rn Your electrical is shit 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Thompson358 Posted April 10, 2022 Author Report Share Posted April 10, 2022 On 4/6/2022 at 3:52 PM, Never Enough Bass said: Your electrical is shit We’ll I have a 390amp alternator now 2 runs of 0 guage And I still have this clipping problem at the same volume when I had the stock alt without a big 3 Link to comment Share on other sites More sharing options...
Thompson358 Posted April 11, 2022 Author Report Share Posted April 11, 2022 So after doing the alternator and everything. I have no voltage drop no dimming everything looks and sounds great just at high volume my clip light stays on and sometimes if it hits a super low note the red light on the amp will flash but it sounds great i don’t hear any distortion should I be worried about it or should I let it slam? Link to comment Share on other sites More sharing options...
Dafaseles Posted April 11, 2022 Report Share Posted April 11, 2022 Where do you set the volume on your phone when you listen to music? 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Thompson358 Posted April 11, 2022 Author Report Share Posted April 11, 2022 The volume on my phone is all the way up the sub has some glue that dried and looks like it was running down the backside of the cone idk if that’s a bad thing but I’m going to test it today to make sure it’s fine Link to comment Share on other sites More sharing options...
Dafaseles Posted April 11, 2022 Report Share Posted April 11, 2022 2 hours ago, Thompson358 said: The volume on my phone is all the way up the sub has some glue that dried and looks like it was running down the backside of the cone idk if that’s a bad thing but I’m going to test it today to make sure it’s fine See what happens if you turn your phone down one or 2 clicks. You might be able to turn the gain or volume up more and get more volume. Like I said before, using a DD-1 with an I phone, the signal clips all the way up, but is clean one click down. I haven't tried with an android yet though. 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Never Enough Bass Posted April 12, 2022 Report Share Posted April 12, 2022 Fuck it let it slam I'm about 2 tourcher test my sia 3500 see if I can blow it up time for a new amp anyways it doesn't push 2 u series like I thought it would don't get me wrong my vision be blurry and my ears pop but it's just not enough lmao 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
Thompson358 Posted April 17, 2022 Author Report Share Posted April 17, 2022 Yeah I thought my single zvx would slam on the Sia 3500 and I wasn’t impressed at all so I switched to a zv4 and looking at 5k amps now hopefully it’s enough Link to comment Share on other sites More sharing options...
