jacob123 Posted April 5, 2022 Report Share Posted April 5, 2022 i gotta zv6 18 and the taramps bass 5k im trynna do a 4th order i did my measurements and i got 14.48 cubes before i add the sealed section. so i was thinking 4 cubes on the sealed side and that would leave around 10 on the ported side just need thoughts before the final decision. Link to comment Share on other sites More sharing options...
Joe X Posted April 6, 2022 Report Share Posted April 6, 2022 Are you wiring to 2 ohm for 3200WRMS? Link to comment Share on other sites More sharing options...
jacob123 Posted April 7, 2022 Author Report Share Posted April 7, 2022 the sub is d2 and the amp is a 1 ohm so i wired it to 1 ohm, how much air space u think the zv6 needs on the seald side Link to comment Share on other sites More sharing options...
Joe X Posted April 7, 2022 Report Share Posted April 7, 2022 Your cone excursion with a 4,10@45Hz 4th bandpass with the Sundown Zv6 18D2 on 5000W is as follows: As you can see at lower frequencies you hit Xmax =35mm, setting your subsonic filter to 20Hz can avoid that happening or consider less than 4 net. Other than that your projected frequency response using a 2.5:1 chamber size ratio will be very peaky like shown in the figure below. Link to comment Share on other sites More sharing options...
kalilac619 Posted April 8, 2022 Report Share Posted April 8, 2022 I’d do 3 cubes sealed side 2000 Suburban 6 runs of 2/0 12 timpano audio mids,6 timpana audio tweets and 1 timpano compression horn per door 8 banks of blue Maxwells + 260ah of Yin Long LTOs 2 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 161.6@38hz DBdrag sealed on the dash… 162.54 outlaw…161.14 Meca headrest Link to comment Share on other sites More sharing options...
