Alex M Posted April 9, 2022 Report Share Posted April 9, 2022 I'm new to the higher end of car audio and within the last month melted the heatsyncs in my previous amp; after i got a new amp I was asked if i was going to keep the amp cool, so in an attempt to keep overheating not an issue I got an SMD-TM1 along with a 5 pack of ARTIC P8 PWM PST fans. Whilst I've searched for an amswer on how to get power to the SMD-TM1, and then wire the fans to the SMD-TM1, I've come up with nothing. I've theorized a possible layout and will submit a picture of it (the amp rack) there you will see multiple distribution blocks going from a single 1/0 guage to 2-4 guage wires, one wore going to my amp and the other 4 guage wire going to a second distribution block that then distributes the power to 4- 8 guage outputs. As for wiring the SMD-TM1 to the fans I am at a loss as to how I'm supposed to do that. Link to comment Share on other sites More sharing options...
Kyblack76 Posted April 10, 2022 Report Share Posted April 10, 2022 https://damore-engineering.myshopify.com/collections/led-car-audio-meters/products/tm-1 click that, and go to manual SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Alex M Posted April 10, 2022 Author Report Share Posted April 10, 2022 Do I wire it directly to the battery or so I use an "add a circut" from my fuse box, and the fans are 4 pin there's only 2 wires from the sensor going to the fans so how does that work? Link to comment Share on other sites More sharing options...
