whoopdeedoo Posted May 21, 2022 Report Share Posted May 21, 2022 Been trying to figure this out for 3 weeks or so. I switched out my CAB amp for a Smart 5 and I can't have a bass knob connected with interference. I changed nothing about the system other than the amp. I've tried my main knob and also my backup, both of which worked fine with my last 2 amps. Whenever I have a knob connected in line with the RCAs I get constant noise through the subs. Even with no music playing or if I turn off my sub option at the headunit. I've checked all my grounds, tried multiple different RCAs, I set my gain with my DD1 and checked it with my Oscope. I tried wrapping wire around the RCAs at the headunit and on the bass knob. I even borrowed a friends Smart 5 Bass version and it did it also. The only thing that's worked was a ground loop isolator but with that connected my DD1 was sensing distortion constantly regardless of gain and other settings so I disconnected the isolator. For the life of me I can't figure this out. I hate using the headunits sub option to adjust bass. Any ideas? 2004 Tahoe Z71 Pioneer 80PRS Taramps Smart 5 Sundown Xv3 15" (2) Mechman 320a XS Power D3400 (2) KnuKonceptz wire and RCAs Slam Panda knob (RJ45 model) Link to comment Share on other sites More sharing options...
CstrokerV Posted May 22, 2022 Report Share Posted May 22, 2022 Might just be the smart 5 doesn’t like the bass knob throw your old amp back in see what happens my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
whoopdeedoo Posted May 22, 2022 Author Report Share Posted May 22, 2022 1 hour ago, CstrokerV said: Might just be the smart 5 doesn’t like the bass knob throw your old amp back in see what happens I sold it when I bought this one. Have to try and track down a half-bridge to test. Didn't have an issue with my other amps but these full bridges are causing problems. I know other people running the Smart 3 with a universal knob not having problems. My car doesn't like em apparently. 2004 Tahoe Z71 Pioneer 80PRS Taramps Smart 5 Sundown Xv3 15" (2) Mechman 320a XS Power D3400 (2) KnuKonceptz wire and RCAs Slam Panda knob (RJ45 model) Link to comment Share on other sites More sharing options...
