2004 Chevy Tahoe (voltage drop issues)
I had a stock 125 amp alternator on my chevy tahoe running my car audio system. Uograded to a 300 amp (off-brand) and Mechman 400 amp. Now im having more voltage drop than I had with my stock 125 amp alternator. Ive checked all connections and everything is good. Only thing i can think is the new alternators arent hooked up correctly. Car audio system consists of ...
*Alpine Halo 9 ilx-f309 headunit
*Underground Power battery delete
*Underground Power 40ah lithium
*JY Power 40ah lithium
*Sundown Audio Salt 3 amps (X 4)
*Sundown Audio Ns v5 d2 subs (X 2)
* custom Sundown Audio sub box
*1/0 power wire (4 runs)
*1/0 ground wire
Any thoughts and/or help would be greatly appreciated.
Yes, each alt starts the vehicle. The 300 amp is ran off factory harness. The 400 mechman is tapped into the factory harness, 1 wire ran to ignition wire (in fuse box), 1 wire ran to charging post. When i start the vehicle the voltmeters read 14.9-15 volts. When theres a deep, long bass rhythm section, the voltmeters go into "LO", and the amps cut off. Spl Labs Bassmeter registering 145-147 dbs at voltage drop issues. No serpentine belt slip. Thabks for your response and information.
Are you running 2 runs of 1/0 power to every amp, and 1 run of ground? Looks like you need more grounds. You have 4 amps running to 2 grounds.  Amps are pulling more power now then previous, and are probably looking for more ground. Wonder if amps are going in to protect.  I would add grounds and recheck.
  • Who's Online   1 Member, 0 Anonymous, 1334 Guests (See full list)
