bigmizzle99 Posted September 30, 2022 Report Share Posted September 30, 2022 I need more electrical. I have an Audio Control LC6.1200 and newly added RF T1500-1bd. I have 1 D3400 and stock alt (150A). Its a Camaro so battery is already in trunk. Voltage is dropping to lows 12s, and I've seen high 11s when listening full tilt. I would like the weight and space savings of Lithium and increased power availability. So, I was planning to add another D3400 to see how the electrical responds before buying a high output alt. BUT, is the Titan8 a primary engine starting battery and can it alone support my electrical needs? The XS Power website is seriously lacking in documentation and any explanatory details. Camaro SS Build Altima build 2.0 Altima build 1.0 Link to comment Share on other sites More sharing options...
CstrokerV Posted September 30, 2022 Report Share Posted September 30, 2022 they have an email and number probably will be faster then answer here my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/ Link to comment Share on other sites More sharing options...
bigmizzle99 Posted September 30, 2022 Author Report Share Posted September 30, 2022 1 hour ago, CstrokerV said: they have an email and number probably will be faster then answer here lol, yes I know....I emailed a separate question 2 weeks ago that went unanswered. I will call today. Camaro SS Build Altima build 2.0 Altima build 1.0 Link to comment Share on other sites More sharing options...
02Blazer Posted October 3, 2022 Report Share Posted October 3, 2022 On 9/30/2022 at 8:37 AM, bigmizzle99 said: I need more electrical. I have an Audio Control LC6.1200 and newly added RF T1500-1bd. I have 1 D3400 and stock alt (150A). Its a Camaro so battery is already in trunk. Voltage is dropping to lows 12s, and I've seen high 11s when listening full tilt. I would like the weight and space savings of Lithium and increased power availability. So, I was planning to add another D3400 to see how the electrical responds before buying a high output alt. BUT, is the Titan8 a primary engine starting battery and can it alone support my electrical needs? The XS Power website is seriously lacking in documentation and any explanatory details. are you pulling more than 300 amps with that system ? if you are some where around that , just get a high output alt , keep your D3400 and you should be good . if that is not enough , build a 32 Ah (3200-4000 watts)-48AH(4800-6000 watts) Headway bank to replace that D3400 you have in the trunk and you should have plenty of power , going that route with the Headway bank , you wouldn't need to buy a high output alt Link to comment Share on other sites More sharing options...
jmanjr82 Posted October 3, 2022 Report Share Posted October 3, 2022 Just keep in mind some people swear you need to delete your battery and just go lithium and others will say you can run agm with headway cells, but not yinglong which is a given as the voltage is vastly different. I can tell you first hand running limitless lithium with stock batt SUCKS! ESPECIALLY in a newer car where it constantly sees 2 different voltages and sends a voltage warning. Headway battery is cheaper, but the alt is probably more beneficial Link to comment Share on other sites More sharing options...
02Blazer Posted October 3, 2022 Report Share Posted October 3, 2022 1 hour ago, jmanjr82 said: Just keep in mind some people swear you need to delete your battery and just go lithium and others will say you can run agm with headway cells, but not yinglong which is a given as the voltage is vastly different. I can tell you first hand running limitless lithium with stock batt SUCKS! ESPECIALLY in a newer car where it constantly sees 2 different voltages and sends a voltage warning. Headway battery is cheaper, but the alt is probably more beneficial never run LTO with an agm , LTO needs around 15.3 , if running on stock charging you'd really wouldn't get the benifit of the LTO running it that low of voltage . Headway will always be better by itself having the alternator just charging the bank . not trying to maintain the agm also . Link to comment Share on other sites More sharing options...
jmanjr82 Posted October 3, 2022 Report Share Posted October 3, 2022 Agreed! Link to comment Share on other sites More sharing options...
bigmizzle99 Posted October 4, 2022 Author Report Share Posted October 4, 2022 I discussed with XSPower and the rep suggested an SB500-34 500 Farad super cap bank and keep the XSD3400 and stock alt. He also said that 1 Titan8 could indeed replace the 2 D3400s. Camaro SS Build Altima build 2.0 Altima build 1.0 Link to comment Share on other sites More sharing options...
