jmanjr82 Posted October 11, 2022 Report Share Posted October 11, 2022 Greetings I have 96 headway says and I was curious how they should be charged? I am currently going through them and most are showing 3.24volt, but range from 3.24 - 3.28 If they read 3.24volts now they don't need charged correct? They can just be made into the banks and charge from the alt? In the event they do need charged can I just use the limitless lithium charger I have? If not what charger should be used like 12v 5a? Feel free to link chargers. I do have balancers 1 per 64ah bank. Link to comment Share on other sites More sharing options...
Baydestrian Posted October 13, 2022 Report Share Posted October 13, 2022 I'm almost 100% sure my buddy who builds banks just uses a NOCO Genius charger. He built my 40ah Headway bank. 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical Link to comment Share on other sites More sharing options...
jmanjr82 Posted October 13, 2022 Author Report Share Posted October 13, 2022 I have a ctek charger also, but its not that I know of meant for lithium. Link to his charger or do you know which one he has? They have like 2amp, 5amp, and 10amp. Link to comment Share on other sites More sharing options...
killerc998 Posted October 14, 2022 Report Share Posted October 14, 2022 I use my Noco-Genius charger. It has a lithium setting. Been using it for about 2 yrs on Headway cells with no problems. Link to comment Share on other sites More sharing options...
02Blazer Posted October 14, 2022 Report Share Posted October 14, 2022 On 10/11/2022 at 11:03 AM, jmanjr82 said: Greetings I have 96 headway says and I was curious how they should be charged? I am currently going through them and most are showing 3.24volt, but range from 3.24 - 3.28 If they read 3.24volts now they don't need charged correct? They can just be made into the banks and charge from the alt? In the event they do need charged can I just use the limitless lithium charger I have? If not what charger should be used like 12v 5a? Feel free to link chargers. I do have balancers 1 per 64ah bank. azon.com/HANMATEK-Programmable-Variable-Regulated-Interface/dp/B07SS77N7K/ref=sr_1_2?crid=22PHWX0MCNHQ9&keywords=rockseed Link to comment Share on other sites More sharing options...
