BassMunky Posted December 15, 2022 Report Share Posted December 15, 2022 How I know if it broken or not working anymore???? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
SnowDrifter Posted December 15, 2022 Report Share Posted December 15, 2022 More information needed ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
BassMunky Posted December 17, 2022 Author Report Share Posted December 17, 2022 Was working the other day, then all of a sudden it doesn't turn on anymore. All wiring is good. And connections Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
SnowDrifter Posted December 18, 2022 Report Share Posted December 18, 2022 You've validated it has ground, +12v, and turn on? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
BassMunky Posted January 19, 2023 Author Report Share Posted January 19, 2023 On 12/17/2022 at 2:26 PM, SnowDrifter said: You've validated it has ground, +12v, and turn on? How? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 19, 2023 Report Share Posted January 19, 2023 11 hours ago, BassMunky said: How? With a multimeter, or even a test light for that matter. Seems like that cheap accurate stinger volt meter like you said in the other post is working pretty well! Link to comment Share on other sites More sharing options...
BassMunky Posted January 20, 2023 Author Report Share Posted January 20, 2023 12 hours ago, audiofanaticz said: With a multimeter, or even a test light for that matter. Seems like that cheap accurate stinger volt meter like you said in the other post is working pretty well! I'm getting power but it not light in g up Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported Link to comment Share on other sites More sharing options...
audiofanaticz Posted January 24, 2023 Report Share Posted January 24, 2023 make sure there is power on the remote too?? if there is then one would think the meter went bad. Link to comment Share on other sites More sharing options...
Never Enough Bass Posted January 26, 2023 Report Share Posted January 26, 2023 It's cheap just buy a new 1 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt Link to comment Share on other sites More sharing options...
sICSoundz Posted January 26, 2023 Report Share Posted January 26, 2023 Or make sure something didn't get disconnected or fix it and save the few bucks. Such a throw away society Link to comment Share on other sites More sharing options...
