threebills Posted December 16, 2022 Report Share Posted December 16, 2022 So I'm hooking up a fosgate t400x4 which will be on 4 -2 ohm 6.5 mids and tweets,with a fosgate t1000 BDCP on 1 fosgate t1d415 (DVC) thats 1000 watts rms(fosgate always underated,even the amps birthsheet is at 1540 watts rms at 2 ohms).So,I know this is overkill,but I don't mind the money cause overkill doesn't hurt.Getting the big 3,and I'll have a 2500 watt cap,I'm gonna run 1/0 from the battery to a splitter,splitter will have4 awg pure copper to the t400(which will have at least 100x4 rms(about 29 amps)) then a 50 amp anl fuse to THAT amp.....then 2awg to the cap,then to the t1000 to a 125 anl fuse(or 100,not sure cause at 1500 it pulls 109 amps,prolly a 100 fuse say(which max is about 1500 watts rms,but prolly never even need it figuring the 15 maybe will run 1200 rms max on a deep note)so my question is.....about the grounds.....since the t400 is split on 4 awg and the t1000 is on 2 awg,should I just ground each amp with the gauge going into the amp straight to a chassis bolt?Like 4 awg ground for the t400 and a 2awg ground for the t1000? Or should I use a block?I was just gonna use the same cable gauges going into each amp coming out as a ground to the same spot.Or do i need to use 1/0 as ground for both amps being that's what i used before the split.I was thinksince it's overkill I could just use the same gauge coming out of the amps as a ground as goin in.Also far as the t1000 into the DVC 15 speakerwire is 4 gauge copper enough?or maybe go 6? Also 1 more question to add,since I have 1/0 positive from the battery do I have to have 1/0 on the big 3 coming from the alternator to the neg of the battery? Thanks in advance for your help...this is bustin my brain a bit and I'm kinda ocd so I like to be perfect lol. Quote Link to comment Share on other sites More sharing options... 0 2
MrSkippyJ Posted December 17, 2022 Report Share Posted December 17, 2022 Ground gauge should be equal to positive side gauge. No need for a grounding block but you certainly use on if you want too. 4g speaker wires??? No. 12g is by far big enough for that amp. The grounds for the battery and alt/engine are so short that you can probably get away with 2 or 4 gauge. Especially if you are running a factory alt. But my own personal OCD wouldn't let me use 1/0 for power and a different gauge for negative. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options... 2k 10.3k 21
