4 Atomic Apxx 15" 4rth Order Bandpass Wall Build
my old wall consisted of 2 apxx 15s in a wall way to big but did a pretty good number a 153.3 at 42 hz's and a 149.8 at 35hz well i wanted more and got a good deal on 2 more apxxs so i couldnt pass it up
well it started with a design
Posted Image
and from the design then came the tear down
Port out
Posted Image
Posted Image
passenger seat out
Posted Image
subs out
Posted Image
Posted Image
baffle out
Posted Image
3 of the 4 subs
Posted Image
testing my dimensions
Posted Image
and sub placement
Posted Image
Posted Image
center console out redoing the wiring and tidying up rcas and so on
Posted Image
tidying up the 0 gauge
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
the first cut x2 sheets
Posted Image
Posted Image
and more pics of the subs just cause
Posted Image
more test fitting
Posted Image
finally everything was cut except the holes
not glued and not flush just thrown together
Posted Image
Posted Image
and now time for the holes
i have no jasper jig or nothing so i made my own
Posted Image
Posted Image
Got circle cut outs
24 cut outs was a bitch on my back working only a foot off the ground
Posted Image
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
and more test fitting to make sure its perfect
Posted Image
a shot at a distance
Posted Image
still not glued and more testing
Posted Image
was not sure if i liked it like this above or like this
Posted Image
figured subs up top would be loudest so i went with that took everything out and started to glue
Posted Image
glued sanded and round over done
can finally mount it for good
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
Posted Image
Posted Image
port in tuned to 27 hz for shits n giggles
Posted Image
Posted Image
and finally clean up
Posted Image
Posted Image
theres about 4 pounds of sawdust in there and im still not done but that is my build for now
took 2 days due to lack of supplies
i ran out of glue and did not have a belt sander but my uncle stopped by and let me borrow his sander and plainer and i dont know where i`d be without them
i`m still waiting for the 4rth sub to come in before i put all the subs in
R.I.P!
(Nov-29-2009)
92 explorer
current build
and yeah i know the back piece of the baffle isnt perfect when i cut it i f`d up and so that is why it is at the back i plan on fixing it up later but its cold out and snowing on and off
Posted Image
the head unit alpine IVA-D105
R.I.P!
(Nov-29-2009)
92 explorer
current build
figured i`d add some pics of the amps
Posted Image
Posted Image
Posted Image
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
Posted Image
Posted Image
Posted Image
Posted Image
Looks like alot of work, can't wait to see the final result man
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
Nice ......ever need any help with a design ...ill help you out ..
thanks man i was wanting to do a clamshell for the 4 15s then looked into a band pass and realized this was the easiest so i went with this
Posted Image
Posted Image
Posted Image
this is what i came up with
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   1 Member, 0 Anonymous, 1009 Guests (See full list)
