How To Recone A Sub
kingsuv
Ok, so here is step by step pictures on how to recone a sub.
So here was the issue.
Posted Image
Now in a normal, easy to get to box, I would just re solider the leads and be on my way. But since I went through all the trouble to pull the box I will upgrade to the new tinsel leads.
BTW, here is the old coil next to the new. Not bad for putting a Maxximus to the pair of them. ;)
Posted Image
So we start by having a good clean surface to work with. We will cut out the old cone.
Posted Image
Next we will cover up the motor.
Posted Image
Posted Image
Now we want to clean off as much material as we could.
Posted Image
Posted Image
Now the fun part. We get to grind.
Posted Image
Posted Image
Then we want to clean off the old leads.
Posted Image
Posted Image
Now normally I would use a grinder not a drill but most of my tools are in the new shop. I we were limited on battery power for todays work.
Look for the rest tomorrow.
Kid labor FTW! :D
whoa thanks for this, im gonna be reconing my sub soon so this should come in handy for sure.
So easy, even a 12 year old can do it ;)
lookin well prepped Bill
I never had to go beyond a box cutter, once you lay that blade flat on the surround or spider surface, it should come clean off with just a few strokes, CA or rubber based glue
Your definitely gonna have some nice clean gluing surface thats for sure
Now that it's clean it's time to get it back together.
I start by marking where the leads go. It's simple i know but a lot easier then not having the leads in the right spot ;)
Posted Image
Posted Image
Nothing like some home made shims to set the coil.
Posted Image
Black CA glue and some activator.
Posted Image
Laid down a nice bead for the spider.
Posted Image
then weighed it down to help it set.
Posted Image
While it's setting I soldered the leads.
Posted Image
Posted Image
Then a nice bead of glue for the surround with clamps to hold it in place.
Posted Image
Now the dust cap can be tricky. I use a piece of tape to hold it while I glue it
Posted Image
then add a little weight to hold it while it sets.
Posted Image
Bingo. Reconed sub.
What brand of CA glue and activator did you use? Also do you spray the basket with the activator then apply the glue or the other way around? What did you use for the shims? I'm about to recone some subs and this helps me a lot! Thanks for the great tutorial!
I just use the house brand from a local RC hobby shop. I apply the glue to the basket and the activator to the cone / spider. The shims are manila folders cut up to fit the coil. took 3 layers for a nice tight fit all around.
