Mechman Alternators
Problems With Alt
well i purchased an alt from mechman and it was the 250 amp alt for a 95 toyota celica. i got a good price and all of that and the alternator is beautiful however it doesnt fit. first off the bolt for the tensioner was to short no problem easy 1$ fix. But now i have an even greater problem the alternator case is so large that it will not fit inbetween the top mount and the bottom mount with enough space to let me slide the alt in and out to get tension on the right size belt. i am wondering if anyone knows a way to fix this or if i should start looking for a new alt.
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
well that suxs I just need to know what to do I've been messing with it for 5 hours and no luck but gotta love direct bolt on's lol
TEAM NEMESIS
my system
Meca scores
I tryed and they are closed untill monday
TEAM NEMESIS
my system
Meca scores
a slightly shorter belt will solve the tensioning issue. If you are having any other problems, Dennis will rectify them for you immeadiatly, just call him at 1-888-MECHMAN.
We sell tons of those units, and a shorter belt is all that should be required for a bolt-in installation.
Thanks
Matt
ok that makes sense I just need to know what you suggest for gettin that smaller belt on and thanks for the help and I didn't wanna sound like an ass I was just really frustrated
TEAM NEMESIS
my system
Meca scores
ok my buddy finagled the belt on and now it's tight but I have voltage problems. With the car on it's at 12 volts and with everything else on it still sits at 12 volts never higher. Got the batt checked and suposidly it's fine and got an amperage test done and that read there was no output but yet it was saying there was14.5 volts out I'm really confused now
TEAM NEMESIS
my system
Meca scores
Sometimes with the new bolt-ons, the clip leads could be backwards. I had the exact same problem putting my new one in and after messing with it for a couple hours, I had to cut and splice a new clip for it reversing the wires.
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
well I guess this will have to wait untill tommorow when I can get them on the phone
TEAM NEMESIS
my system
Meca scores
  • Who's Online   1 Member, 0 Anonymous, 1233 Guests (See full list)
