Coolwazabi Posted June 15, 2009 Report Share Posted June 15, 2009 how do i do it ??? i assume just remove the nut ?? Quote Link to comment Share on other sites More sharing options...
badasschevy Posted June 16, 2009 Report Share Posted June 16, 2009 you'll need a pickle fork or aka tie rod seperator to break it free from the knuckle. if it has a jam nut or sleave with a bolt(s) loosen them up, but before you try removing the tie rod measure or count the amount of threads showing on the rod itself. you'll need to know that for when you put the new one's on,so you can get it close within speck. you'll need an alignment afterwards. Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components Link to comment Share on other sites More sharing options...
V1G1LANT3 Posted June 17, 2009 Report Share Posted June 17, 2009 I wouldn't use a pickle fork to loosen it because they almost always tear the grease boot. Smack the tie rod end or knuckle with a big hammer and it should pop loose while being careful to stay clear of the boot. Before I loosen the nut I put white out on the threads so I put it about the same spot when you put the new one on. LIke he said, loosen nut or sleeve and the end should just screw off. Quote Link to comment Share on other sites More sharing options...
B Slaps Posted June 17, 2009 Report Share Posted June 17, 2009 (edited) this is in the wrong section however vigilant is right. edit: wrong person Edited June 17, 2009 by B slaps yo mama Quote I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/ Link to comment Share on other sites More sharing options...
cracker Posted June 17, 2009 Report Share Posted June 17, 2009 I wouldn't use a pickle fork to loosen it because they almost always tear the grease boot. Smack the tie rod end or knuckle with a big hammer and it should pop loose while being careful to stay clear of the boot. Before I loosen the nut I put white out on the threads so I put it about the same spot when you put the new one on. LIke he said, loosen nut or sleeve and the end should just screw off. x2 its not bad at all and if it dont budge(tie rod/ lock nut) then put heat on it/ torch Quote March 2010 SOTM winner my old buildhttp://www.stevemeadedesigns.com/board/topic/50219-dank-aka-crackers-bonne-new-v2-build-in-the-works-hahahaaaaaa/page__hl__crackers my youtube page - http://www.youtube.com/profile?user=jackiedan04#g/u my feedback - http://www.stevemeadedesigns.com/board/topic/56540-official-cracker-feedback/ i need tacos and bass to live!!!!! and will NEVER change hahaaaa TEAM NOIZE VIOLATION Link to comment Share on other sites More sharing options...
V1G1LANT3 Posted June 17, 2009 Report Share Posted June 17, 2009 Forgot that he really don't have to worry about the boot in this case..he's replacing it anyways. Quote Link to comment Share on other sites More sharing options...
