2006 Chevy 2500hd Duramax 4dr.
Ok-So this build has been "in the works" for a LOOOOOONG time, I'm just finally getting to "get busy" on it for reals and I also finally have a decent camera so I can snap pix of every screw/wire crimp for yall.
Ride: 2006 Chevy 2500HD Duramax Diesel 4dr/quadcab/BigAssSOMMABITCHIN 4X4TRUCK.(it's the topic title, did you miss it somehow?)
Posted Image
Posted Image
Posted Image
System:
Deck: Stock unit (tape/cd/XM Radio)
Front Mids: Infinity Kappa 6 1/2" coax
Rear Mids: Infinity Kappa 6 1/2" coax.
Subs: 3-Kicker L7-8's (dual 4ohm)
Sub amp: Kenwood KAC 9152D 1800w Monoblock
Mid amp: Kenwood KAC 8452-4 chann.
Xstatic Battcap 800
Stinger Platinum Dist. block.
0/1ga power front to back
(Maybe) an Audio Control Epic-160
Runnin some 0/1ga wire.
Posted Image
Posted Image
Here's my "custom" (ghetto/homemade) wire puller. Essentially just a random ass piece of bent steel rod that I can wrap a straightened closehanger around and use to pull the hell outta a 0/1ga that won't thread thru the firewall w/ out mucho pulling. I wrapped it in an old sock to be easier on my hands.
Posted Image
Posted Image
Posted Image
GM sidepost in gold.
Posted Image
Threw some fatmat on the back wall
Posted Image
Here's the 1st box I buit him just to get him HOOKED on audio and convinced I could fit something in there despite the limited space-It's 2 Credence 8's (round kicker solobarics)
Posted Image
Posted Image
Posted Image
So once I had em convinced I could fit something cool in there...he got all excited and wanted to go as big as possible. So...my other buddy and I hooked him up on his Bday with 3 Kicker L7 8's I found for not that much BNIB.
Posted Image
No usable space under seats....GREAT!
Posted Image
Posted Image
So it's all "magically" gotta hide itself behind the seats...box, amp rack, and electrical. oh fun.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
  • Replies 145
  • Created
  • Last Reply
New Box: 3-L7-8's, lil under 1.5ft^3 net, sealed (that's .5ft^3 per sub)
Posted Image
Posted Image
The amp rack spans the whole back wall of the cab.
It doesn't sit on top of the box, it is/will be mounted to the back wall via 8mm bolts/nuts from inside the back wall sheet metal/interior back wall, and hover about 1/2" above the box.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
More box buildin...
Posted Image
Checkin fit on Box+Rack+Battcap
Posted Image
Posted Image
Posted Image
What fun would this box be w/out...PLEXI!
Posted Image
Posted Image
3/4" acrylic
Posted Image
BUT..
The place I got the plexi said they only had a 30 and 45degree angle jig....so they couldn't bevel it for me.LAME.
OK fine so I made my own damn jig.
Posted Image
Posted Image
Posted Image
Posted Image
And then I chopped the piece into 3 inserts.
Posted Image
Posted Image
Hells yea I'm lightin this beezy up!
If you see plexi...there WILL be lights.
I wouldn't replace a perfectly good piece of 3/4" mdf that was already cut to fit nicely w/ sub holes and all, with a $150 piece of plexi just so you could see how small the interior of the box is, it's gettin lit up fasho...and I have some tricks for that one too.
Posted Image
Posted Image
Posted Image
So...I jigged out some cut outs from the underside of the box in the shape of a 15" neon tube for each sub/section.
Posted Image
I had to mod/chop down the neon tubes cuz they were a lil bulkier than i wanted so just roto-zipped off all the non-essentials.
Posted Image
Posted Image
This is lookin great man. Any worries about sub excursion clearance with that back seat so close?
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
NOPE.
Subs will be mounted to the plexi which is set IN 3/4" from the edge.
There will be a trim piece surrounding the plexi and subs to hide the screws/ugly edges/glued areas behind the plexi and everything inside and out will be covered nicely. Just stay tuned I'll have more pics as I get time. I have like a billion pics and this bish aint even put together yet.
Did a lil more w/ the plexi inserts today and decided I'mma switch em to 1/2" plexi instead of 1/4". Thin stuff is too prone to cracking when screws go thru to clamp it down and I dont trust glue alone.
Posted Image
Posted Image
Posted Image
Primered
Posted Image
Almost ready for these guys
Posted Image
Drew in where the trim & plexi will show
Posted Image
Posted Image
Great work man everything looks perfect.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
  • Who's Online   1 Member, 0 Anonymous, 180 Guests (See full list)
