Amp Ideas?
TeejayBee
Instead of 2 amps, think about 1 mono amp and wire the 2 subs together which would drop the amp down to 1 ohm.
I like running 1 amp per sub in set-ups using only 2 subs, it helps keep the rise down.
¿ǝɯɐƃ ǝɥʇ
So your saying its a good idea to run to amps ?
IMO yes, not too hard either, it may be a bit more expensive, but I think it will perform better than a single 2K rms amp.
And in your case all you have to have is a run of 1/0 to the back, with a distribution block and run the 1/0 in and a run of 4 gauge to go to each amp.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   1 Member, 0 Anonymous, 1333 Guests (See full list)
