How exactly does a subwoofer work?
the bigger the magnet, generally the more efficient the woofer will be. when the current is going through the voice coil, its electromagnetism is affected by the magnetic field of the strong motor, which causes the voice coil (which is attached to the cone) to move more air.
kind of like comparing an Xplod to a BTL. stronger motor (along with other characteristics) is a means for a louder woofer with higher sensitivity.
http://www.bcae1.com/speaker.htm
http://www.bcae1.com/speakrat.htm
Thats not really true,
Larger motor has very little to nothing to do with efficiency and sensitivity.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
i know its not really that true, hence i put "generally"
edit: but then why does lets say, the example i gave, the xplod and BTL. both being 12" speakers, giving lets say 100w to each. the btl would be louder since its much more efficient since the motor has a MUCH stronger force (and other things)
BL, and motor force is kinda like Torque for a car motor vs. Horsepower.
A strong motor doesnt mean a woofer will be sensitive, it just means that it will have the strength to push a more massive cone and be able to push through power compression.
In the higher SPL range over 155 dB, tremendous air pressure is placed on the cone as it moves. So alot of force is need to push against this air resistance, thats when powerful motors are needed.
But sensitivity and efficiency is more based on the coil charachteristics and mass and weight of the moving parts as well as how the suspension allows the cone to travel.
Ed Lester
ShowtimeSPL Host
My old Build Log
This.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
top plate is kind of light a lens, it focuses on the magnetic field, different top plates will achieve different results- narrow, or widen the magnetic field, with a loser, or tighter VC gap, or taller top plate, or shorter top plate, or you can use a top plate with a split design, to created a dual magnetic field, for more coil travel, more linear excursion, without causing distortion, or losing motor strength
There is also Under hung design, and over hung design
1 the coil is taller than the top plate
the other the top plate is really tall, maybe 1.5" tall, and the coil is really short 1.5" tp vs a 0.75 vc example
Power handling is mostly dependent on coil surface area, to dissipate heat, and wire gauge has a little to do with that as well
Different wire gauge gets you lesser or higher ohms common wire gauge is about 24/25g on a 2.5" coil, 22-18gauge on a 3" coil, and about 18-17gauge on a 4" coil
How many layers a coil has, 2, 4, 6, 8 layers determine other factors, like mH - Le of the coil, which will deal a lot with the efficiency of the coil/cone assembly in the magnetic gap
A lot of people are using lesser layers, and much longer winding widths now to produce higher efficiency woofers, to create higher Bl, and lower handling woofers
  • 1 month later...
  • Who's Online   1 Member, 0 Anonymous, 1757 Guests (See full list)
