Pauliesnite93 Posted November 14, 2009 Report Share Posted November 14, 2009 it is H23,W49,D30 port size is H21,W10,L11 it says it is tuned to 34 hz and it is 14.61 ft and how wood i tune this box higher Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
Kranny Posted November 14, 2009 Report Share Posted November 14, 2009 why is the port in the middle of the box? you can tune higher by making the port wider/taller Quote Link to comment Share on other sites More sharing options...
TeejayBee Posted November 14, 2009 Report Share Posted November 14, 2009 what size sub? Quote Link to comment Share on other sites More sharing options...
kl0wn Posted November 14, 2009 Report Share Posted November 14, 2009 why is the port in the middle of the box? you can tune higher by making the port wider/taller I am wondering this too, and yeah bro, you gotta give us more detail, by like what it's going in, where, what kind of sub, and what kind of power you plan on running to it Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
Gotloud555 Posted November 14, 2009 Report Share Posted November 14, 2009 That's huge box for that single sub.. Quote Link to comment Share on other sites More sharing options...
-Hobby- Posted November 14, 2009 Report Share Posted November 14, 2009 (edited) If this is for the AQ's you should stick to one thread. Other Thread This makes it harder for people to help you. If it is for the 2 AQ's your port size is getting a little to big. Try and stick with 16 in per sq ft net not gross. A little smaller would be better than bigger. I think this box gets 2 AQ 18's just dosnt show it in the pict. That or the box is Way to big. Edited November 14, 2009 by HobbyWerks Quote Link to comment Share on other sites More sharing options...
kl0wn Posted November 14, 2009 Report Share Posted November 14, 2009 If this is for the AQ's you should stick to one thread. This makes it harder for people to help you. If it is for the 2 AQ's your port size is getting a little to big. Try and stick with 16 in per sq ft net not gross. A little smaller would be better than bigger. I think this box gets 1 AQ 18's just dosnt show it in the pict. That or the box is Way to big. Do you mean 2? Because I can picture it having the 2nd sub on the other side, then I could understand why the port is in the middle with 2, not 1 Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
-Hobby- Posted November 14, 2009 Report Share Posted November 14, 2009 Yea 2, had to do a quick edit, you beat me to it lol. Quote Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted November 15, 2009 Author Report Share Posted November 15, 2009 ya it i going to have two aq hdc3 18 copper coils running 2000 rms each. it was screwing up when i made the second circle and tried to push it down to cut it out. it is going to have a anther sheet of mdf on top. this is my second time using sketch up. can some one tell what size the port should be i used the thing what the one guy on this site made and that port looks all wrong. the one guy said put the port one the side of the box should i do this . and it is going in the back of a 2001 expedition. and why all u guy use Tahoes Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
Pauliesnite93 Posted November 15, 2009 Author Report Share Posted November 15, 2009 i want it to be tuned to 35-39 hz. would it be smart to flip the sub to get more room in the box that would be like 7 cubic feet per sub if i fliped and dose i help cool the coils. on that box calculator from this site is it true that when u click the slot port button it screw with the tuning Quote Whip:2004 Ford Expedition Headuint:Pioneer AVH-P4200DVD Alt:MechMan 270 Amp Big 3: Yes Rear batts:2x Kinetik HC2400 Power Wire:carolprene 0/2 welding wire Volt Meter:X Scorpion Front stage:Kicker KS6502 Rear stage:Polk audio 6x8s High Amp:Boston acoustic GT-4100 Sub stage:Audio Que HDC3 18s Copper Coils D2 Low Amp:Audiopipe AP30001D Box:6ft3 96in2 34hz 146.8 dbs @ 35hz Sealed up Link to comment Share on other sites More sharing options...
