TeejayBee Posted November 17, 2009 Report Share Posted November 17, 2009 So Im thinking its time to get a new alt thats ment for car audio xP what would you suggest im running about 3000watts pm with info or post here again thanks Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted November 17, 2009 Report Share Posted November 17, 2009 So Im thinking its time to get a new alt thats ment for car audio xP what would you suggest im running about 3000watts pm with info or post here again thanks Our 270 amp unit would be perfect, it is on sale for only $399 shipped. Here are the specs: -270 amp output -Full output by 1800 rpm engine speed -Excellent output at idle, 165 amps by 800 rpm engine speed !! -Competition rectifier for durability and power handling -Zero Gauge cable ends included -Easy bolt in installation -Oversized pos. and Neg. studs for large cable connections -Accepts vehicle's OEM alternator plug -Proof of Performance Dyno Sheet -100% brand new unit, made in USA -One year warranty It also will work with the new XS power VCM (voltage control module) that gives you in-dash control of your voltage, and a digital display of alternator voltage. The VCM is on sale for only $149 if you want to add it. It simply plugs into the alternator harness. Regards Matthew 1-888-MECHMAN [email protected] Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
