DAMM dude you got some major skills. Keep the pics coming.
Thanks man. Pics are rollin in..
DAm dude. How old are you? Work looks amazing.
Thank you..I'm no spring chicken, I'll tell ya that....haha...I'm 27
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
Looking fantastic man!! Superior quality work being done.
Thank you. I try to do quality work and not get into too much of a rush....It pays off in the end.
Guest Nismofreak
Dam....Well good luck man. Car is nice as the future system is.
Using Baltic Birch for the wall....I will never go back to MDF...its superior in every aspect.
Posted Image
Posted Image
Floor started
Posted Image
Posted Image
Posted Image
In the previous pic, I added two more pieces to the 1 1/2" bracing, and ran a few beads on the inside of the truck. Then plug welded the rest of it from the outside.
Starting on the back. That piece was screwed to the brace, and I drilled two holes and filled the cavity between that and the sheetmetal with expanding foam...the back wall of the cab is now solid as a rock.
Posted Image
More pics later.....gotta get back to work. :lol:
I'm lost, it had a blow through, and your are eliminating that, or youy are dinog a blow through?
VERY nive truck dude, that bish is cleeeaaan.
Thank you. Yes I am getting rid of the blowthrough(hence the sheetmetal) and I am putting in a wall. :)
nice work man! looks good
Thank you.
Here is the back of the sub wall up..it is glued and screwed/bolted to the brace
Posted Image
Posted Image
Started on the baffle...two layers here..holes marked for the subs also
Posted Image
Sub holes and recesses cut...
Posted Image
Test fit for shits and giggles (At this time I had the fourth sub in my daily driver)
Posted Image
Posted Image
This is lookin so sweet! I'm a firm believer that subs should ALWAYS be recessed. Good job so far, keep it up!
I love your suspension setup too, real clean!
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
  • Who's Online   0 Members, 0 Anonymous, 978 Guests (See full list)
