ChevyBoy Posted November 21, 2008 Report Share Posted November 21, 2008 I heard soldering good you better electrical connection than crimping? Is that true? I did a couple soldering but it seem like I'm having a bit trouble with the wire jacket. It seem to be melting a bit.yes its true its a better connection. bring the flame up a little higher on the ring terminal and hit it on the back side of it. Quote Link to comment Share on other sites More sharing options...
Gotloud555 Posted November 21, 2008 Report Share Posted November 21, 2008 yes its true its a better connection. bring the flame up a little higher on the ring terminal and hit it on the back side of it. THanks! I will be soldering all my ring terminal. I should heat the top of the ring head? O.K i will try that and i see what happen. Quote Link to comment Share on other sites More sharing options...
ChevyBoy Posted November 21, 2008 Report Share Posted November 21, 2008 heat it on the back side and try and do it as fast as you can that way it melts less of the jacket Quote Link to comment Share on other sites More sharing options...
BAGGEDBIRDS.com Posted November 21, 2008 Report Share Posted November 21, 2008 I cut my insulation a little less than I normally would so that if it melts a little and the terminal slide down the wire a little the wire won't stick out the front of the terminal. Practice, Practice. Quote 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator Link to comment Share on other sites More sharing options...
creyc Posted February 12, 2009 Report Share Posted February 12, 2009 deleted for stupidity reasons Quote 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck Link to comment Share on other sites More sharing options...
Gotloud555 Posted March 25, 2009 Report Share Posted March 25, 2009 (edited) I prefer soldering because it make the cable stiff and wouldn't cause the cable to slip out from the terminal. I had crimping terminal before but i not strong enough as soldering. Well, guess what i finally now understand how to make a smooth shiny slide soldering. Wall la! IF you do it right the hot soldering will smoke up on the ring termial on top. IT will come out shiny and smooth. See the photo!! Edited March 25, 2009 by Gotloud555 Quote Link to comment Share on other sites More sharing options...
moh.vze.com Posted April 13, 2009 Report Share Posted April 13, 2009 (edited) http://www.parts-express.com/pe/showdetl.c...tnumber=370-080 Did I buy wrong solder? Mine seems rather thin. Edited April 13, 2009 by moh.vze.com Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
moh.vze.com Posted April 15, 2009 Report Share Posted April 15, 2009 I read an interesting post on another forum: http://www.caraudio.com/forum/showpost.php...mp;postcount=25 [ Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
Stephen Posted April 15, 2009 Report Share Posted April 15, 2009 I read an interesting post on another forum: http://www.caraudio.com/forum/showpost.php...mp;postcount=25 Opinions? if you are running so much power through your wire that its heating up you need either bigger wire or more runs of wire. Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
moh.vze.com Posted April 15, 2009 Report Share Posted April 15, 2009 if you are running so much power through your wire that its heating up you need either bigger wire or more runs of wire. Hmm True. I was just reading my solder and it says "Melts at 375 degrees F", so I think soldering is fine for the Big 3. Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
