so i was driving along ht the gas a little harder cause i was inbetween 2 trucks and i didnt like it next thing i know it says check coolant temp rises smokeing but not much hotter then normal... usuall around 98-101c but now was around 111-117(highest it went) i got home poped the hood clear liquid everywere... i dont know much about engines but im guessin somethign to do with coolant ballast or radiator?
1996 deville on 18" full face rims
-2 gauge wire.
-a2400db
-RE SE-X in a 4ftc box tuned to 32hz
-tview touch double din
-rockford punch 6x9s(rear)
-mtx 6.5(front)
front and rear stage will soon be changed build log will start as soon as it aint cold!
If it was smoking and smelled of antifreeze than you definately blew a radiator line i believe.
formerly known as Jaylor Swift
yessir it smelt horrible! and might i add the car runs fine..
-2 gauge wire.
-a2400db
-mtx 6.5(front)
You just blew the radiator to your coolant i used to do to that with my 91 cutlass i replaced it atleast three times b.c it was a beater car . But if it smells bad its deff coolant , that stuff is so nasty just when you drive dont step on your gas to hard and try to get it to a shop asap.
-TeeJay
Check to see if any of your hoses or blown or anything.
its night right now cant do much... but lets say its either of the 2 thermostat or just a hose how much do u think the repair would be?
-2 gauge wire.
-a2400db
-mtx 6.5(front)
  • Who's Online   0 Members, 0 Anonymous, 741 Guests (See full list)
