Old kicker F10a 4 ohm free air seiries
jbloud47
So Im trying to design an enclosure for 4 of these F10a's to go into a crown vic. Need some more input on these subs, kicker recommends 1.25 @ 36 for one 10 seems kinda big to me. Plotted them on BBP plots don't look to bad with 5 cubes @ 36 with 64 sq in port
A New Begining Starting Over
2003 F-150 extended Cab
Head unit: Pioneer 880
Speakers: JBL 6.5 comps and 8's in doors
Amp: JBL 100x4 & JBL GTO700.1
Sub Amp: ?
Subs: Possible 4 SX 15's or 2 SX 18's
Box:18-20 sq ft @ 30
Batts: Still Need
alt: mechman still to order
Wire: Lots of 1/0
the F is a Freeair application, but they can be used in a ported enclosure. They are 1.25 and i wouldn't tune too low. Pre 90's build, technology has changed, spider, suspension changes since then.
They are SVC, so watch power in a ported application. If doing somewhat decent power, look at sealing them. They have a stiffer suspension than the C or Compeition series in same era.
Behind every great man....is an underwear tag!
So would you say if i go ported then tune in the upper 30's or 40hz, Ill prob end up just going sealed something quick and easy. thanks for the help
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
any recommendations on what size sealed they would prefer?
Sub Amp: ?
Batts: Still Need
Wire: Lots of 1/0
