Drawing to many amps?
Only reason you could draw "too many amps" through that would be poor connection (resistance causes heat) or a short to ground. That wire you're using should handle that amp without even blinking.
Edited by STEvil
Hammerdown... 1%
heres some pics
your trying to draw too many amps and the + wire from bat to fuse needs to be at least 10 inches (cant tell if it is) and i wouldnt have the + wire from the fuse to the amp that short but thats just me and i also wouldnt cross the possitive and negative how you have them between the battery and amp. complete the big 3 correctly man haha theirs no point in a big 1 or big 2
-Car: 2006 Ford expedition King Ranch
-Subs: 2 FI BTLs 18 fully loaded
-amps: 2 sundown SAZ 3000D
-Alternator: DC Power 260 amps
-Batterys: 2 optima yellowtops
-A whole shit load of 0 guage knu hyper flex and raptor cable
-Rockford Fosegate 3sixty
Fairly pointless place for a fuse... do you ever see that actually shorting out?
Completely beside the fact that I don't see a fuse on the other piece of 0 gauge to the battery, major fire hazard. If there isn't a fuse just out of that camera shot I would start by installing a 250A fuse on that run of wire.
10.x volts fo' life!
yeah there is just not in the pic. got tomorrow off so ill be finishing the big 3 tomorrow
2 15 RE SE
1 Audiopipe 1500d
Sony HU
Batcap 800 in the back
Team Tex~Flex
  • Who's Online   1 Member, 0 Anonymous, 1176 Guests (See full list)
