Mechman Alternators
MECHMAN ADVICE NEEDED
I have a 69 camaro 350 in my 64impala and need a alt that can keep 2 kinetik 16volt batts. charged .
any advice you have is appreciated
No prob-
I'm assuming you are going to keep the stock 12 volt alt to charge the front 12 volt batt and run the vehicle?
I'm also going to assume you will be driving both alternators with v belts?
If so, I would reccomend our one wire, large case GM 16 volt 200 amp alternator. (200 amps is the most amperage you can run on a single v-belt without massive slippage) It does 125 amps at idle, and is selectable between 12 and 16 volts. It features our custom rectifier for total street durability, and oversized positive and negative studs for big/multiple cable runs. Best of all, you don't have to do any additional wiring, just 1/0 positive and ground cables from the alternator straight to the 16 volt batteries.
