I DONT GET IT IM ABOUT TO SELL IT ALL!!!!
all that equipment and no volt meter lame
And i agree, 0 gauge grounds for starters and go from there
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
What kind of power wire are you using? And are you running four gauge to the 1000/1?
he's using 0 gauge for the jl amp then 4 gauge for the mid's and highs
And his problem is he needs a new alternator like atleast a 200 amp then he will be good
Introduce a no fat chicks in the whip rule.
Im gonna have tech force make up a sign that says that and put it on my car lol
hes using 4 gauge for the power on the mids amp from the batt in the back..
no zero from the batt up front to a splitter to 2 four gauge and the hc800 is only hooked up to the jl 1000/1
and brand new batt up front yellow top D35 deep cycle just got it like an hour ago
the door speaker amp the arc audio isnt running a 2nd battery its only running off the one under the hood
it go's zero from up front under hood to the back
then theres a fused anl splitter that the zero plugs into then on the other side of the splitter is 2 four gauge
both amps in the back are getting 4 gauge
its just that the jl 1000/1v2 has an extra battery a kinetik HC800 for just the JL
the kinetik is not hooked up to the arc audio amp for my doors
That's not necessarily the case
Car
1996 Sable LS
8,000K Bi-Xenon HID's
Pioneer Premier DEX-P1R
Diamond Audio D351, Diamond Audio D362i, Diamond D3TAK off Kicker ZX200.4
Custom 15" 13w7 motor, 3.5" aluminum coils dual 1 ohm off NV-AM25001
Dynamat Dynaliner Second Skin Damplifier Pro
Stock 130A Alternator
My Build
Truck
1995 Ford F-150 Flareside XLT
10,000K Bi-Xenon HID's, 15,000K Bi-Xenon HID's
Kicker KS6502, KS400 off Pioneer Premier PRS-D4100F
Truck Build
Ref(s) Rogers, Jared, Mikesmith0890, Twigz, DHFHades, BASS14, Solo_X18, mrafrica, camino_1to3, kickerassman
[speakerman9000] 5:43 pm: if sony sucks so bad how come my amps still work when i had 3 12s on it
[capalass23] 11:27 pm: wow u grand man poopin out babys like hto cakes
[KevinniveK] can u have sex later please hes helping me
well, go get some 0g and do the big 3
http://www.stevemeadedesigns.com/board/ind...showtopic=13280
thats the tutorial
go get a DMM and set your gains with
Team_DC-Derrick's Youtube
Team DC Audio
Swap out the 4awg for 1/0awg on the JL and see if it helps
Car
1996 Sable LS
My Build
Truck
Truck Build
i have one zero gauge ground
the zero gauge ground i have is on the kinetik HC800 on the neg post to the body then the other neg wire on the kinetik is 4 gauge going to the jl 1000/1v2
and the arc audio amp for my doors has a 4 gauge ground to the body both have good metal to body grounds
the amount of reserve doesnt matter if you cant properly charge it! youre getting low voltage because youre asking too much of your alt. small sedans dont create a great amount of power! if you had a sufficient power supply (alt), you wouldnt see voltage drop.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   1 Member, 0 Anonymous, 1831 Guests (See full list)
