Sanitarium Posted February 10, 2010 Report Share Posted February 10, 2010 i run a pair of amps strapped to my D2's in series parallel for a 2 ohm final load. you could run an AP3000D in 2 ohms final for close to its sticker rating of 3000@2ohms Link to comment Share on other sites More sharing options...
vj226966 Posted February 10, 2010 Author Report Share Posted February 10, 2010 i run a pair of amps strapped to my D2's in series parallel for a 2 ohm final load. you could run an AP3000D in 2 ohms final for close to its sticker rating of 3000@2ohms First sorry .5 is what i meant.I need close to 1000 per sub,no more Link to comment Share on other sites More sharing options...
vj226966 Posted February 10, 2010 Author Report Share Posted February 10, 2010 First sorry .5 is what i meant.I need close to 1000 per sub,no more Also 140 alt amp,big three done.Will get another batt if needed Link to comment Share on other sites More sharing options...
vj226966 Posted February 11, 2010 Author Report Share Posted February 11, 2010 did web search and cannot find a diagram for wiring 2 dual 2 ohm subs.Question is i guess s it posible to wire them at 1 or 2 ohms Link to comment Share on other sites More sharing options...
enemyofsilence Posted February 11, 2010 Report Share Posted February 11, 2010 here are some options for wiring... Team Bass-Hz Link to comment Share on other sites More sharing options...
vj226966 Posted February 11, 2010 Author Report Share Posted February 11, 2010 here are some options for wiring... found that.So my options are find a amp that makes power at 2 ohms or 1 amp per sub.Thank you! Or find a Orion 2100 hcca lol Link to comment Share on other sites More sharing options...
wL<3bass Posted February 11, 2010 Report Share Posted February 11, 2010 0.05............. No amp is history will run at 0.05 ohms. Ummm yes there is.... Orion Concept 97.3 Specs: Output Power at 12V: Stereo 2 x 0.5W @ 4 ohms 2 x 1W @ 2 ohms 2 x 2W @ 1 ohms 2 x 4W @ 0.5 ohms 2 x 8W @ 0.25 ohms 2 x 16W @ 0.125 ohms 2 x 32W @ 0.0625 ohms 2 x 64W @ 0.0312 Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references... Link to comment Share on other sites More sharing options...
Ben Building Posted February 11, 2010 Report Share Posted February 11, 2010 Maybe try an OPTI 2000D. Link to comment Share on other sites More sharing options...
jizazz12 Posted February 11, 2010 Report Share Posted February 11, 2010 the new AQ 3500.1 does 2600 at 2 ohm's at 14.4 volts. i have the same problem,been looking at this amp myself. 2007 Chevy Impala LS 1 Crescendo 3KWP 1Crescendo C1000/4 2 DC lvl 4 15's with lvl5 dual .7 coils 1Audio Control Matrix 1 Pioneer P880PRS 1 300 amp Iraggi alt All power runs done with Knu flex 0/1 guage 1 optima yellow top under the hood 1 XS 5100 and two Deka's in the trunk 4 Crescendo MP-8 mid bass drivers 2 DB Drive p5 5 D Pro Audio tweeters Link to comment Share on other sites More sharing options...
fritosaregood Posted February 11, 2010 Report Share Posted February 11, 2010 Id say to get two saz 1000s or 1500s and strap them. if you do that you can run them at 2 ohms daily. the sundowns run good at .5 daily, I never had a problem with my 3000d or 1500d, but im trying to get back to running at 1 ohm to be more effecient seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
